[GRASS-user] Importing .e00 file
M S
mseibel at gmail.com
Wed Aug 15 07:48:33 EDT 2007
I hope someone else has a better solution that doesnt involve using
arcCatalog. If you dont have ArcCatalog, someone else will have to provide
a solution for you.
the e00's pre-date arcMap, and apparently from what I have experienced, even
though the .e00 are ASCII interchange files, they are not the same as an
"ESRI ASCII Raster file" produced by ArcCatalog within ArcMap. (arc/info
workstation .e00 ascii file <> arcMap .txt ascii file)
I cant see how to import a raster .e00 file directly. I would be grateful
to hear from someone how to do this. I checked the GDAL page also, but
could not find the answer.
what will work is this:
Use ArcCatalog (or arc/info workstation) to import the .e00 file to an ESRI
GRID.
Use ArcToolBox, under "Conversion Tools", then "From Raster", then "Raster
to ASCII" dialog.
Input the raster, Input the output ASCII raster file in the dialog box.
This will output a <outfile>.txt file.
this ASCII text file can be imported using the
r.in.arc(File-->Import-->Raster Map-->ESRI Arc/Info ASCII grid)
Mark
On 8/15/07, Rainer M. Krug <Rainer at krugs.de> wrote:
> M S wrote:
> > Looks like it is a raster/GRID, and not vector?
> I might agree with that. So I should use m.in.e00 - but as far as I have
> seen, it is not available for grass 6.2. Is there another way of
> importing them
> > On 8/15/07, *Rainer M. Krug* <Rainer at krugs.de <mailto:Rainer at krugs.de>>
> > wrote:
> > Hi
> > System:
> > SuSE Linux 10.2
> > grass 6.2
> > e00compr-1.0.0
> > avce00-2.0.0
> > I want to import an .e00 file, but I get the following error
> message:
> > > v.in.e00 -v file=aveanrfl.e00 type=area vect=test
> > An error may appear next which will be ignored...
> > E00 Compressed ASCII found. Will uncompress first...
> > ...converted to Arc Coverage in current directory
> > Importing areas...
> > ERROR: Cannot open data source: aveanrfl
> > An error occurred. Stop.
> > I get the same area message if I omit the extension .e00 from
> > file=aveanrfl.e00
> > I attach the first lines of the .e00 file:
> > EXP 0 /DUMP/GISDATA/RSAMAPGD.E00
> > GRD 2
> > 1075 910 1-0.21474836470000E+10
> > 0.16667000000000E-01 0.16667000000000E-01
> > 0.16091670000000E+02-0.34875030000000E+02
> > 0.34008695000000E+02-0.19708060000000E+02
> > 403 403 403 403
> 404
> > 405 407 407 408
> 421
> > 420 429 433 439
> 427
> > 433 436 426 428
> 429
> > 432 433 434 447
> 448
> > 448 447 448 464
> 460
> > 459 464 480 472
> 477
> > 482 469 487 494
> 485
> > 490 488 487 496
> 484
> > 479 484 485 472
> 477
> > Any idea how I can import this file?
> > Thanks,
> > Rainer
> > NEW EMAIL ADDRESS AND ADDRESS:
> > Rainer.Krug at uct.ac.za <mailto:Rainer.Krug at uct.ac.za>
> > RKrug at sun.ac.za <mailto:RKrug at sun.ac.za> WILL BE DISCONTINUED END OF
> > MARCH
> > Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation
> > Biology (UCT)
> > Plant Conservation Unit
> > Department of Botany
> > University of Cape Town
> > Rondebosch 7701
> > South Africa
> > Tel: +27 - (0)21 650 5776 (w)
> > Fax: +27 - (0)86 516 2782
> > Fax: +27 - (0)21 650 2440 (w)
> > Cell: +27 - (0)83 9479 042
> > Skype: RMkrug
> > email: Rainer.Krug at uct.ac.za <mailto:Rainer.Krug at uct.ac.za>
> > grassuser mailing list
> > grassuser at grass.itc.it <mailto:grassuser at grass.itc.it>
> > http://grass.itc.it/mailman/listinfo/grassuser
> RKrug at sun.ac.za WILL BE DISCONTINUED END OF MARCH
> Biology (UCT)
> Rondebosch 7701
> South Africa
> Skype: RMkrug
> Rainer at krugs.de
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070815/57a91c26/attachment.html
