[GRASS-user] Importing .e00 file
Rainer M. Krug Rainer at krugs.de
Wed Aug 15 08:43:57 EDT 2007
Thanks for your help.
I expectged it to be problematic. What I will do: install grass 5.4.2 as
well and import to a format which can be read from both.
Thanks,
Rainer
M S wrote:
> I hope someone else has a better solution that doesnt involve using
> arcCatalog.  If you dont have ArcCatalog, someone else will have to
> provide a solution for you.
> the e00's pre-date arcMap, and apparently from what I have experienced,
> even though the .e00 are ASCII interchange files, they are not the same
> as an "ESRI ASCII Raster file" produced by ArcCatalog within ArcMap.
> (arc/info workstation .e00 ascii file <> arcMap .txt ascii file)
> I cant see how to import a raster .e00 file directly.  I would be
> grateful to hear from someone how to do this.  I checked the GDAL page
> also, but could not find the answer.
> what will work is this:
> Use ArcCatalog (or arc/info workstation) to import the .e00 file to an
> ESRI GRID.
> Use ArcToolBox, under "Conversion Tools", then "From Raster", then
> "Raster to ASCII" dialog.
> Input the raster, Input the output ASCII raster file in the dialog box.
> This will output a <outfile>.txt file.
> this ASCII text file can be imported using the r.in.arc
> (File-->Import-->Raster Map-->ESRI Arc/Info ASCII grid)
> Mark
> On 8/15/07, *Rainer M. Krug* <Rainer at krugs.de <mailto:Rainer at krugs.de>>
> wrote:
>     M S wrote:
>      > Looks like it is a raster/GRID, and not vector?
>     I might agree with that. So I should use m.in.e00 - but as far as I have
>     seen, it is not available for grass 6.2. Is there another way of
>     importing them
>     <mailto:Rainer at krugs.de> <mailto:Rainer at krugs.de
>     <mailto:Rainer at krugs.de>>>
>      > wrote:
>      >     Hi
>      >     System:
>      >     SuSE Linux 10.2
>      >     grass 6.2
>      >     e00compr-1.0.0
>      >     avce00-2.0.0
>      >     I want to import an .e00 file, but I get the following error
>     message:
>      >      > v.in.e00 -v file=aveanrfl.e00 type=area vect=test
>      >     An error may appear next which will be ignored...
>      >     E00 Compressed ASCII found. Will uncompress first...
>      >     ...converted to Arc Coverage in current directory
>      >     Importing areas...
>      >     ERROR: Cannot open data source: aveanrfl
>      >     An error occurred. Stop.
>      >     I get the same area message if I omit the extension .e00 from
>      >     file= aveanrfl.e00
>      >     I attach the first lines of the .e00 file:
>      >     EXP  0 /DUMP/GISDATA/RSAMAPGD.E00
>      >     GRD  2
>      >            1075       910 1-0.21474836470000E+10
>      >       0.16667000000000E-01 0.16667000000000E-01
>      >       0.16091670000000E+02-0.34875030000000E+02
>      >       0.34008695000000E+02-0.19708060000000E+02
>      >                 403           403           403
>     403           404
>      >                 405           407           407
>     408           421
>      >                 420           429           433
>     439           427
>      >                 433           436           426
>     428           429
>      >                 432           433           434
>     447           448
>      >                 448           447           448
>     464           460
>      >                 459           464           480
>     472           477
>      >                 482           469           487
>     494           485
>      >                 490           488           487
>     496           484
>      >                 479           484           485
>     472           477
>      >     Any idea how I can import this file?
>      >     Thanks,
>      >     Rainer
>      >     NEW EMAIL ADDRESS AND ADDRESS:
>      >     Rainer.Krug at uct.ac.za <mailto:Rainer.Krug at uct.ac.za>
>     <mailto:Rainer.Krug at uct.ac.za <mailto:Rainer.Krug at uct.ac.za>>
>      >     RKrug at sun.ac.za <mailto:RKrug at sun.ac.za>
>     <mailto:RKrug at sun.ac.za <mailto:RKrug at sun.ac.za>> WILL BE
>     DISCONTINUED END OF
>      >     MARCH
>      >     Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation
>      >     Biology (UCT)
>      >     Plant Conservation Unit
>      >     Department of Botany
>      >     University of Cape Town
>      >     Rondebosch 7701
>      >     South Africa
>      >     Tel:            +27 - (0)21 650 5776 (w)
>      >     Fax:            +27 - (0)86 516 2782
>      >     Fax:            +27 - (0)21 650 2440 (w)
>      >     Cell:           +27 - (0)83 9479 042
>      >     Skype:          RMkrug
>      >     email:  Rainer.Krug at uct.ac.za <mailto:Rainer.Krug at uct.ac.za>
>     <mailto: Rainer.Krug at uct.ac.za <mailto:Rainer.Krug at uct.ac.za>>
>     <mailto:Rainer at krugs.de <mailto:Rainer at krugs.de>>
>      >     _______________________________________________
>      >     grassuser mailing list
>      >     grassuser at grass.itc.it <mailto:grassuser at grass.itc.it>
>     <mailto:grassuser at grass.itc.it <mailto:grassuser at grass.itc.it>>
>      >     http://grass.itc.it/mailman/listinfo/grassuser
>     RKrug at sun.ac.za <mailto:RKrug at sun.ac.za> WILL BE DISCONTINUED END OF
>     MARCH
>     Biology (UCT)
>     Rondebosch 7701
>     South Africa
>     Skype:          RMkrug
RKrug at sun.ac.za WILL BE DISCONTINUED END OF MARCH
Biology (UCT)
Rondebosch 7701
South Africa
Skype:		RMkrug
       	Rainer at krugs.de
