[GRASS-user] winGRASS 6.2.2 and 6.3.cvs
Luigi Ponti
lponti at infinito.it
Sat Aug 18 08:51:23 EDT 2007
Ted Nebitko wrote:
> Native winGRASS 6.3.cvs (wingrass63_cvs20070801, 01-Aug-2007).
> I get the following error in the start-up script after pressing "enter
> grass" on placing location and mapset numbers in the opening gui
> (using grass63.bat)
> ERROR: program 'g.gisenv' cannot be executed because: Neither a
> command line (cmd) or interactive (inter) version was found.
> mail: not found while executing "exec g-gisenv get=GISDBASE" invoked
> from within
> "set env(GISDBASE) [exec g.gisenv get=GISDBASE]"
> (file "d:/grass/grass-6.3.cvs\etc\gm\gm.tcl" line31)
> Were you able to start this native wingrass version without problems?
Yes Ted,
It worked fine for me.
I noticed that you have the grass folder in D:\. The only thing I can
think of is the advice included in the README file
http://moritz.homelinux.org/grass/wingrass/README, which says "You might
want to uncomment and adapt some of the environment variables in
grass/bin/grass63.bat, notably WINGISBASE if you did not unzip the
package it in C:\". But off course you already took care of that.
Regards,
Luigi
> ----- Original Message -----
> *From:* Luigi Ponti <mailto:lponti at infinito.it>
> *To:* grassuser at grass.itc.it <mailto:grassuser at grass.itc.it>
> *Cc:* wingrass at grass.itc.it <mailto:wingrass at grass.itc.it>
> *Sent:* Thursday, August 16, 2007 11:19 AM
> *Subject:* [GRASS-user] winGRASS 6.2.2 and 6.3.cvs
> Dear list,
> On my MS Window XP machine, I have:
> - Cygwin GRASS 6.1.cvs (last Huidae Cho's version);
> - Cygwin GRASS 6.2.2-1 (18-Jul-2007);
> - Native winGRASS 6.3.cvs (wingrass63_cvs20070801, 01-Aug-2007).
> Some observations:
> The three do not interfere with each other, except for the native
> winGRASS 6.3.cvs that needs to reset GISDBASE: in ~/.grassrc6 to
> an absolute path at startup (c:\cygwin\home\$USER\ as opposed to
> \home\$USER\ which is enough for Cygwin): next time you use a
> Cygwin version, it complains that it does not find the database
> folder (and vice versa when you use start the native version after
> a Cygwin/GRASS session). I understand one is very likely to
> survive this inconvenience, but is there a way around it?
> If I use the cygwin_grass.bat script to start GRASS 6.2.2-1 as
> described at <http://grass.itc.it/grass62/binary/mswindows/#icon>,
> I receive the error message:
> Application initialization failed: this isn't a Tk
> applicationcouldn't connect to display "127.0.0.1:0.0"
> Error in startup script: dynamic loading is not currently
> available on this system
> while executing
> "load /usr/local/lib/tk8.4/../libtk8.4.a Tk"
> ("package ifneeded" script)
> invoked from within
> "package require Tk 8.0"
> invoked from within
> "package require -exact BWidget 1.2.1"
> (file "/usr/local/grass-6.2.2/etc/gtcltk/options.tcl" line 15)
> invoked from within
> "source $env(GISBASE)/etc/gtcltk/options.tcl"
> (file "/usr/local/grass-6.2.2/etc/gis_set.tcl" line 29)
> while executing
> invoked from within
> invoked from within
> (file "/usr/local/grass-6.2.2/etc/gm/gm.tcl" line 24)
> However, if I use a modified grass.bat script (the one that starts
> GRASS 6.1.cvs, only with grass62 instead of grass61 in the "run
> xterm ..." line) everything works fine.The cygwin_grass.bat script
> only works if there is an Cygwin/X Server already running from a
> previous Cygwin/GRASS session (the Cygwin/X Server stays on after
> exiting GRASS -- you have to manually shut it down). It sounds
> like grass62 starts before startx has finished, but this is just
> my impression. Is there a known fix to this? I have found no
> answer in email archives.
> Last thing: I have tried to run a shell script on the native
> winGRASS 6.3.cvs (by typing the script name at the bottom box of
> "Output - GIS.m" window and then pressing the different "run"
> buttons) but it always fails (the script works fine on
> Cygwin/GRASS versions) saying:
> - nothing if I press "Run";
> - nothing if I press "Run (Background)";
> - error message if I press "Run UI":
> couldn't execute "ita.sh": no such file or directory
> while executing
> "exec -- $program --tcltk"
> (procedure "run_ui" line 6)
> invoked from within
> "run_ui [string trim [.gronsole.win.text get 1.0 end]]"
> invoked from within
> ".gronsole.command.runui invoke"
> ("uplevel" body line 1)
> invoked from within
> "uplevel #0 [list $w invoke]"
> (procedure "tk::ButtonUp" line 24)
> invoked from within
> "tk::ButtonUp .gronsole.command.runui
> (command bound to event)
> - if I press "Run in Xterm", a Windows command prompt flashes
> briefly and then disappears.
> At first I thought it was a matter of end of line characters,
> since I noticed that the shell scripts of the native 6.3.cvs
> version included in the "scripts" folder had CR/LF end of line
> (and they seem to work if invoked in the way I described above for
> my own script), while the Cygwin version of the same scripts had
> LF end of line. But after converting end of lines to CR/LF, I get
> the same results as described above when I tried to run the
> script. Any hints on how try running homemade scripts on native
> winGRASS?
> Thanks and regards,
> Luigi
> grassuser mailing list
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070818/0ad7038f/attachment.html
