[GRASS-user] i.pr memory error
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Mon Aug 20 11:24:29 EDT 2007
On Monday 20 August 2007 15:21:25 Markus Neteler wrote:
> hi Martin,
> I have updated the old GRASS 5 sites API to legacy GRASS 6 sites API for
> i.pr.training. Not sure if that helps.
> Check that you don't have an empty file ipr_training_test in the current
> directory.
that was the problem
> If it still fails, please
> - post a gdb backtrace
> - replicate it with Spearfish or the new North Carolina data set
thanks - it is working now - but I have still to figure out how, because I
don't understand Italian.
cheers, Martin
> Martin Wegmann wrote:
> > hello,
> > I compiled i.pr from svn and when executing this command:
> > i.pr.training map=in_elev,in_land vis_map=in_elev
> > training=ipr_training_test
> > rows=11 cols=11 class=2
> > Speicherzugriffsfehler
> > I get "memory access error".
> > I had a similar message using g.copy a while ago but it was solved with
> > make -C general/manage clean
> > make -C general/manage CFLAGS1='-g'
> > from the ML.
> > I did:
> > make distclean
> > export CVSROOT=:ext:martin at grasscvs:/grassrepository
> > export CVS_RSH=ssh
> > cvs update -dP grass6
> > cd grass6
> > sudo ./configure --with-tcltk-includes=/usr/include/tcl8.4
> > --with-postgres-includes=/usr/include/postgresql
> > --with-gdal=/usr/local/bin/gdal-config   --enable-largefile
> > make
> > -> errors for i.pr appear
> > # for i.pr:
> > make MODULE_TOPDIR=/home/wegmann/software/grass/grass6/
> > sudo make install
> > any idea where the error might be? TIA Martin
