[GRASS-user] i.pr memory error
Markus Neteler
neteler at itc.it
Mon Aug 20 09:21:25 EDT 2007
hi Martin,
I have updated the old GRASS 5 sites API to legacy GRASS 6 sites API for
i.pr.training. Not sure if that helps.
Check that you don't have an empty file ipr_training_test in the current
directory.
If it still fails, please
- post a gdb backtrace
- replicate it with Spearfish or the new North Carolina data set
Markus
Martin Wegmann wrote:
> hello,
> I compiled i.pr from svn and when executing this command:
> i.pr.training map=in_elev,in_land vis_map=in_elev
> training=ipr_training_test
> rows=11 cols=11 class=2
> Speicherzugriffsfehler
> I get "memory access error".
> I had a similar message using g.copy a while ago but it was solved with
> make -C general/manage clean
> make -C general/manage CFLAGS1='-g'
> from the ML.
> I did:
> make distclean
> export CVSROOT=:ext:martin at grasscvs:/grassrepository
> export CVS_RSH=ssh
> cvs update -dP grass6
> cd grass6
> sudo ./configure --with-tcltk-includes=/usr/include/tcl8.4
> --with-postgres-includes=/usr/include/postgresql
> --with-gdal=/usr/local/bin/gdal-config --enable-largefile
> make
> -> errors for i.pr appear
> # for i.pr:
> make MODULE_TOPDIR=/home/wegmann/software/grass/grass6/
> sudo make install
> any idea where the error might be? TIA Martin
View this message in context: http://www.nabble.com/i.pr-memory-error-tf4297941.html#a12235867
Sent from the Grass - Users mailing list archive at Nabble.com.
