[GRASS-user] [GRASS]Problem importing geotiff with r.in.gdal
Raffaello Brondi
raffaello.brondi at pisa.intecs.it
Tue Aug 21 12:55:01 EDT 2007
hi all
I'm developing a processing-service using GRASS and I've got a problem
when importing GeoTiff rasters.
The import operation is implemented by means of r.in.gdal
When I import a geotiff created by means of a WCS request using
geoserver 1.5, the data is shifted by half a pixel; that is, the point
of origin has half a pixel offset.
The problem seems to be due to a wrong handling of meta-tags by r.in.gdal.
The import works correctly (without any shift) if geotiffs with the
meta-tag AREA_OR_POINT=Area are imported. However, a WCS request to
geoserver 1.5 results in a geotiff using AREA_OR_POINT=point. It seems
that Grass ignores the difference: the coordinates of the point of
origin are handled as if they refer to the corner, instead of the center
of the pixel.
I've looked at gdal options, but I found nothing about this. Has anyone
encontered the same problem?
thanx
Raffaello
