[GRASS-user] [GRASS]Problem importing geotiff with r.in.gdal
Frank Warmerdam
warmerdam at pobox.com
Tue Aug 21 13:51:59 EDT 2007
Raffaello Brondi wrote:
> hi all
> I'm developing a processing-service using GRASS and I've got a problem
> when importing GeoTiff rasters.
> The import operation is implemented by means of r.in.gdal
> When I import a geotiff created by means of a WCS request using
> geoserver 1.5, the data is shifted by half a pixel; that is, the point
> of origin has half a pixel offset.
> The problem seems to be due to a wrong handling of meta-tags by r.in.gdal.
> The import works correctly (without any shift) if geotiffs with the
> meta-tag AREA_OR_POINT=Area are imported. However, a WCS request to
> geoserver 1.5 results in a geotiff using AREA_OR_POINT=point. It seems
> that Grass ignores the difference: the coordinates of the point of
> origin are handled as if they refer to the corner, instead of the center
> of the pixel.
> I've looked at gdal options, but I found nothing about this. Has anyone
> encontered the same problem?
Raffaello,
This is a long standing issue with GDAL and geotiff. I take the position
that pixel-is-point in geotiff does not change the interpretation that should
be made of the tie point while some others take the opposite opinion.
I don't have any suggestions for how to work around this.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
