AW: [GRASS-user] Problems with r.terraflow and r.thin
Maciej Sieczka tutey at o2.pl
Tue Aug 21 15:21:09 EDT 2007
Christian Braun wrote:
> Hi,
> ok I had to learn that you can't compare the results of r.terraflow and
> r.watershed regarding the watershed generation. I think r.watershed gives me
> the better results, so I will try to use this module.
> But I still have the problem with r.thin to get rid of the linear features
> describing watersheds. The pics I had attached are, of course, the results
> of thining my watersheds of r.terraflow. First pic result watersheds of
> r.terraflow, second pic the thining result.
Christian
Forgive me if I got you wrong, but are you by any chance running r.thin
on a raster map made of adjacent watershed polygons? Please note that
r.thin is supposed to be used for thinning raster *line* features. The
manual reads: "Thins non-zero cells that denote linear features in a
raster map layer".
If you need watershed borders as raster lines, you can use r.to.vect to
extract watersheds as vector polygons (areas) and rasterise their
boundaries with v.to.rast type=line (if this doesn't work, convert
boundaries into lines first with v.type, and run v.to.rast type=line on
this).
Maciek
