AW: [GRASS-user] Problems with r.terraflow and r.thin
Christian Braun
christian.braun at tudor.lu
Wed Aug 22 02:34:51 EDT 2007
Thanks for your answer, I missunderstood the meaning of r.thin.
But how can I get rather compact and smooth polygons representing watersheds
without any slivers or attached/appended fractals of the size of one raster
cell?
Is it possible to solve such a problem with v.clean or something like a
"raster smoothing" with r.neighbour?
Christian
> -----Original Message-----
> From: Maciej Sieczka [mailto:tutey at o2.pl]
> Sent: Tuesday, August 21, 2007 9:21 PM
> To: Christian Braun
> Cc: 'Hamish'; grassuser at grass.itc.it
> Subject: Re: AW: [GRASS-user] Problems with r.terraflow and r.thin
> Christian Braun wrote:
> > Hi,
> > ok I had to learn that you can't compare the results of r.terraflow
> > and r.watershed regarding the watershed generation. I think
> > r.watershed gives me the better results, so I will try to
> use this module.
> > But I still have the problem with r.thin to get rid of the linear
> > features describing watersheds. The pics I had attached are, of
> > course, the results of thining my watersheds of
> r.terraflow. First pic
> > result watersheds of r.terraflow, second pic the thining result.
> Christian
> Forgive me if I got you wrong, but are you by any chance
> running r.thin on a raster map made of adjacent watershed
> polygons? Please note that r.thin is supposed to be used for
> thinning raster *line* features. The manual reads: "Thins
> non-zero cells that denote linear features in a raster map layer".
> If you need watershed borders as raster lines, you can use
> r.to.vect to extract watersheds as vector polygons (areas)
> and rasterise their boundaries with v.to.rast type=line (if
> this doesn't work, convert boundaries into lines first with
> v.type, and run v.to.rast type=line on this).
> Maciek
