[GRASS-user] v.surf.nnbathy
Luigi Ponti lponti at infinito.it
Thu Aug 23 06:39:09 EDT 2007
Thanks Carlos,
Your version works fine but I had to use the Hamish trick posted at
http://www.nabble.com/do-not-export-categories-with-v.out.ascii-t4142590.html
    v.out.ascii input="${VECTOR}" format=point dp=3 |  cut -f1-3 -d'|'
    |  tr '|' ','  > $TMP.${PROG}.input_xyz
because the fs (field separator) option is not available in the
GRASS-6.2.2 version of v.out.ascii that I am using.
Kind regards,
Luigi
Carlos "Guâno" Grohmann wrote:
> Luigi (and everyone else)
> can you try this version?
> I must be going crazy or something. Apparently, I did the changes in
> r.surf.nnbathy back when I started that thread you cited, about a
> month ago.. but I forgot to test it and submit it..
> I did a fast test here and it worked fine, with a 3D vector points layer.
> hope it works!
> cheers
> Carlos
> On 8/22/07, Luigi Ponti <lponti at infinito.it> wrote:
>>  Carlos: Thanks for your prompt reply.
>>  I am using r.surf.nnbathy 1.9, 2007.01.02, and if I don't enter any raster
>> name, it complains:
>> ERROR: Raster map not found
>>  How can the script work if I don't give it an input name? I did not
>> understand what is the "second option" you mentioned in your message, so I
>> am asking whether the following command line corresponds to what you mean:
>> r.surf.nnbathy input= output=3D_vector_name alg=nn
>>  Sorry for my bad intuition and thanks again,
>>  Luigi
>>  Luigi, I just went to look at r.surf.nnbathy, and we _can_ use it to
>> interpolate 3D vector points.
>> just don't enter any raster, and use the second option, for a 3D vector.
>> works well, and it is fast.
>> cheers
>> Carlos
>>  Dear list,
>> Is there any working version of v.surf.nnbathy around? From this recent post
>> it did not sound like an impossible thing. I am looking to replace
>> v.surf.idw with a more robust interpolation method (natural neighbour?)
>> in my mapping routine -- my input is scattered 3D vector points. I am
>> just checking to see if somebody else already did it before trying to
>> modify r.surf.nnbathy myself (I am not really a programmer).
>> Thanks and regards,
>> Luigi
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070823/d64a0caa/attachment.html
