[GRASS-user] v.surf.nnbathy
    Vincent BAIN
    bain at toraval.fr
    Thu Aug 23 01:33:39 EDT 2007
I'm catching up your discuss in a hurry, but if it can help, for a
couple of weeks I've been using r.surf.nnbathy to generate TINs :
http://www.mail-archive.com/grassuser@grass.itc.it/msg00891.html
I turn my vector 3D points into a raster, then make the interpolation
(with the 'l' option) with r.surf.nnbathy, it works fine for me.
And sorry if I flunk !
VB
Le mercredi 22 août 2007 à 23:13 +0100, Carlos "Guâno" Grohmann a
écrit :
> Luigi (and everyone else)
> can you try this version?
> I must be going crazy or something. Apparently, I did the changes in
> r.surf.nnbathy back when I started that thread you cited, about a
> month ago.. but I forgot to test it and submit it..
> I did a fast test here and it worked fine, with a 3D vector points layer.
> hope it works!
> cheers
> Carlos
> On 8/22/07, Luigi Ponti <lponti at infinito.it> wrote:
> >  Carlos: Thanks for your prompt reply.
> >  I am using r.surf.nnbathy 1.9, 2007.01.02, and if I don't enter any raster
> > name, it complains:
> > ERROR: Raster map not found
> >  How can the script work if I don't give it an input name? I did not
> > understand what is the "second option" you mentioned in your message, so I
> > am asking whether the following command line corresponds to what you mean:
> > r.surf.nnbathy input= output=3D_vector_name alg=nn
> >  Sorry for my bad intuition and thanks again,
> >  Luigi
> >  Carlos "Guâno" Grohmann wrote:
> >  Luigi, I just went to look at r.surf.nnbathy, and we _can_ use it to
> > interpolate 3D vector points.
> > just don't enter any raster, and use the second option, for a 3D vector.
> > works well, and it is fast.
> > cheers
> > Carlos
> >  Dear list,
> > Is there any working version of v.surf.nnbathy around? From this recent post
> > http://www.nabble.com/do-not-export-categories-with-v.out.ascii-t4142590.html
> > it did not sound like an impossible thing. I am looking to replace
> > v.surf.idw with a more robust interpolation method (natural neighbour?)
> > in my mapping routine -- my input is scattered 3D vector points. I am
> > just checking to see if somebody else already did it before trying to
> > modify r.surf.nnbathy myself (I am not really a programmer).
> > Thanks and regards,
> > Luigi
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070823/a9c1aae6/attachment.html
