[GRASS-user] is anything wrong with download site?
Sun Aug 26 23:30:01 EDT 2007
ante_anzulovic wrote:
> I'm trying to install grass 6.2 on windows using cygwin, after completing
> the steps (http://geni.ath.cx/grass.html#toc5), I found few problems.
> First if I choose to install version 6.2.1-1 I get the error "download
> incomplete, try again?", no matter what I try. Second, if I try to install
> version 6.2.2-1 everythiong works, except I have a problem with wish
> command. I tried to set up enviroment variable manually, but of course
> it turns out wish isn't downloaded at all, I searched everything (tcl/tk
> is downloaded).
what does "which wish" say from a cygwin terminal prompt? If you type
"wish" at the prompt do you get a little square window to pop up?
Hamish
