[GRASS-user] Reprojection from LLC to UTM (various zones)
Miriam España mespana at ugr.es
Tue Aug 28 05:29:33 EDT 2007
Maciej Sieczka wrote:
> Miriam Espan~a wrote:
>> yes, Maciek, I'm visualizing 3D voxels map, that are in lcc proyection,
>> covering the next area:
>> north: 48.070938 (degrees)
>> south: 21.178000 (degrees)
>> east: -68.766000 (degrees)
>> west: -109.461250 (degrees)
>> top: 14551.891 (meters)
>> bottom: 36.294 (meters)
> lcc units are not degrees. What does the "g.region -g" and "g.proj -p"
> say?
Ok...
GRASS 6.3.cvs (Lambert2):~ > g.region -g
n=48.070938
s=21.178
w=-109.46125
e=-68.766
nsres=0.79096876
ewres=1.01738125
rows=34
cols=40
cells=1360
GRASS 6.3.cvs (Lambert2):~ > g.proj -p
-PROJ_INFO-------------------------------------------------
name       : Lambert Conformal Conic
datum      : nad27
towgs84    : -22.000,157.000,176.000
proj       : lcc
ellps      : clark66
a          : 6378206.4000000004
es         : 0.0067686580
f          : 294.9786982000
lat_0      : 36.0000000000
lat_1      : 60.0000000000
lat_2      : 30.0000000000
lon_0      : -85.0000000000
x_0        : -61.8400000000
y_0        : 19.0000000000
-PROJ_UNITS------------------------------------------------
unit       : meter
units      : meters
meters     : 1.0
It's a concept error from me. I've imported the dem with r.in.bin form
-180,180,90,-90, and, for this reason, 1 degree is equivalent to a meter in
my location. Because of that, when I put coordinates as if it would be
lat/long coordinates, I see the part of the world I expected, I supposed. I
didn't realized this (thanks).
>> from an ascii 3d file. I have a DEM (500 km resolution) that covers all
>> the
>> world,
> The whole Earth in a conic projection? Something's wrong here.
No. I imported a DEM with r.in.bin. I  know that the original map I try to
perform in GRASS covers the region above in a lcc projection with those
parameters, and I only want to see this part of the world (but the file I've
got covers all the world, independent of the projection (it's a binary
file)).
>> that I can see in Nviz (sometimes the corners of the dem are lost in
>> the infinite).
>> I visualize a volume over the orography (dem).
>> Sometimes, nviz crashes, but the reason to transform maps from lcc to utm
>> is
>> because of the visualization of the isosufarces is not correct in
>> lambert,
>> and it was suggested to me in the irc, that nviz can't manage voxels 3d
>> in
>> lcc, only XY or maybe UTM.
> As Glynn already has pointed out, that's not correct.
> Maciek
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Ok... then, Nviz is independent from the projection. But, then, how can i
georrefer a volume? I know that the ascii 3d volume has been calculated with
a projection (it's derivated from Vis5D), but, falling apart with this, the
secuence steps to solve my problem can be like this ¿?:
1- Import terrain from the file in a XY location
2- set the region to the area i try to see
3- extract that area in other map
4-reproject the new map to lcc
5-import the volume without projection in lcc
Then, I must check before that volume and new map of the area has the same
2D dimensions (not adjust with g.region... only g.region t=Top b=bottom, to
visualize the volume)...
I'm going a little crazy with this task. Thanks to all for all your
patient... sorry so much for the inconvenience. Any suggestion to resolve it
would be appreciate.
Miriam
View this message in context: http://www.nabble.com/Reprojection-from-LLC-to-UTM-%28various-zones%29-tf4316273.html#a12364804
Sent from the Grass - Users mailing list archive at Nabble.com.
