[GRASS-user] Reprojection from LLC to UTM (various zones)
Maciej Sieczka tutey at o2.pl
Tue Aug 28 11:46:05 EDT 2007
Miriam,
Ok, if I got you right you have a volume (3D raster) projected in lcc,
imported into a GRASS location which has it's projection set up
according to this volume. Now you want to visualise your volume over a
DEM. But your DEM is in latlong "projection". If this is right, you
should propably be doing like this:
1. Import DEM into a location that has the same projection as DEM
(propably, it's latlong on WGS84 ellipsoid; the EPSG code 4326); let's
call the location "source" and let's assume you are working in mapset
"miriam".
2. In "source" location:
g.region rast=DEM
3. In the "target" lcc location, the mapset your volume is in, do:
g.region rast3d=the_volume_name
r.proj in=DEM out=DEM_lcc mapset=miriam location=source
This will re-project a subset of the whole DEM which covers your
volume; if you want a bigger piece of DEM, enlarge region before
r.proj. Read r.proj and g.region manual.
Hope it works.
Maciek
