[GRASS-user] Re: Fwd: r.le Problem
Leonardo Lami
lami at faunalia.it
Thu Aug 30 08:55:19 EDT 2007
An other information that can help, the setup file is:
SAMPLINGFRAME 0|0|1|1
MASKEDOVERLAYAREA
martin1|n=4850628.86253491|s=4850251.53666561|e=1672192.43512311|w=1671561.85196298
MASKEDOVERLAYAREA
martin2|n=4850628.86253491|s=4850251.53666561|e=1672192.43512311|w=1671561.85196298
MASKEDOVERLAYAREA
martin3|n=4850628.86253491|s=4850251.53666561|e=1672192.43512311|w=1671561.85196298
MASKEDOVERLAYAREA
martin4|n=4850628.86253491|s=4850251.53666561|e=1672192.43512311|w=1671561.85196298
MASKEDOVERLAYAREA
martin5|n=4850628.86253491|s=4850251.53666561|e=1672192.43512311|w=1671561.85196298
MASKEDOVERLAYAREA
martin6|n=4850628.86253491|s=4850251.53666561|e=1672192.43512311|w=1671561.85196298
MASKEDOVERLAYAREA
martin7|n=4850628.86253491|s=4850251.53666561|e=1672192.43512311|w=1671561.85196298
RASTERMAP dtm_interpol_2005 at leo
VECTORMAP martin at leo
Lyke you can see the coordinates are ever the same for the seven masks
and they are the coordinates of the work region:
GRASS 6.3.cvs (Toscana):~ > g.region -p
projection: 99 (Transverse Mercator)
zone: 0
datum: rome40
ellipsoid: a=6378388 es=0.006722670022333322
north: 4850628.86253491
south: 4850251.53666561
west: 1671561.85196298
east: 1672192.43512311
nsres: 2.99464976
ewres: 3.00277695
rows: 126
cols: 210
cells: 26460
regards
Leonardo
Leonardo Lami ha scritto:
> Hi all,
> I have make a little test on r.li.setup using an overlayed vector like
> sample areas.
> I set up a raster file as sampling frame, than a vector as overlayed
> layer. Then I set up the sampling frame as "Whole map", and the sampling
> areas as "Select areas from overlayed vector layer".
> At this poin r.le.setup opens a xmon and draws the choosen raster
> *without *overlayed vector polygons and asks me "Is this area ok?" and a
> name to assign to it. R.li.setup makes it for seven times ever *without*
> shows the overlayed vector than I can click on "Save setting".
> I thinked that r.le.setup showed me the various polygons of the choosen
> vector and that the problem is only on the visualization, but the
> problem is that the choosen vector have *only one* polygon....
> When I run r.li.shannon it says:
> Cannot make stat of
> /home/leo/.r.li/history//home/leo/.r.li/history/martin configuration file
> Non riesco ad aprire il file di intestazione per [ in (null)]
> CHILD[pid = 8570]: unable to open mask ... continue without!!!
> CHILD[pid = 8569]: unable to open mask ... continue without!!!
> CHILD[pid = 8568]: unable to open mask ... continue without!!!
> CHILD[pid = 8567]: unable to open mask ... continue without!!!
> CHILD[pid = 8566]: unable to open mask ... continue without!!!
> CHILD[pid = 8565]: unable to open mask ... continue without!!!
> CHILD[pid = 8564]: unable to open mask ... continue without!!!
> CHILD[pid = 8563]: unable to open mask ... continue without!!!
> CHILD[pid = 8562]: unable to open mask ... continue without!!!
> CHILD[pid = 8561]: unable to open mask ... continue without!!!
> Are there other users that work on the r.li package?
> Serena, Davide e Stefano, have you this problem in your last version?
> Thanks of all
> Ciao
> Leonardo Lami
> Paolo Cavallini ha scritto:
>> Hi Martin.
>> Never seen this. Leo, could you please check?
>> All the best.
>> pc
>> Martin Besta ha scritto:
>>> Sorry, my previous message was not complette...my e-mail client or I was
>>> wrong:)
>>> Hi Paolo,
>>> I have tried r.li <http://r.li> for Shannon index calculation...BUT...
>>> I wanted to set my rectangles from vector layer as a sampling areas,
>>> however, if I try in r.li.shannon to choose configutration file (made
>>> beforehand) I recieve this error message:
>>> Cannot make stat of
>>> /home/martin/.r.li/history//home/martin/.r.li/history/natura_clean
>>> configuration file
>>> Illegal filename. Character <#> not allowed.
>>> Can't open header file for [(#å·P#å·#A¿ in (null)]
>>> CHILD[pid = 6797]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
>>> CHILD[pid = 6796]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
>>> CHILD[pid = 6795]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
>>> CHILD[pid = 6794]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
>>> CHILD[pid = 6793]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
>>> CHILD[pid = 6792]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
>>> CHILD[pid = 6791]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
>>> CHILD[pid = 6790]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
>>> CHILD[pid = 6789]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
>>> CHILD[pid = 6788]: unable to open (#å·P#å·#A¿ mask ... continue without!!!
>>> I tried various vector layer to check this problem, but it is happening
>>> every time.
>>> I think, the problem is about the configutration file.
>>> My procedure was:
>>> First set up the raster file as sampling frame, than vector as overlayed
>>> layer.
>>> Second set up the sampling frame as Whole map, than set up the sampling
>>> areas as Select areas from overlayed vector layer.
>>> Finally Save settings. This file I have choosen as configuration file
>>> for r.li.shannon (as test with r.li.simpson too, but with the same effect) .
>>> Could you check my technique for errors?
>>> I need necessarily this index for my work. However r.le.pixel even
>>> r.li.shannon seems to couldn't work with my data sets.
>>> Thanks
>>> Martin
>>> 2007/8/7, Paolo Cavallini < cavallini at faunalia.it
>>> <mailto:cavallini at faunalia.it>>:
>>> Hi Martin.
>>> Is this http://grass.itc.it/grass63/manuals/html63_user/r.li.html
>>> <http://grass.itc.it/grass63/manuals/html63_user/r.li.html> not
>>> enough?
>>> I have something, but I'm afraid you will not understand it, as it is in
>>> Italian.
>>> However, the behaviour of r.li <http://r.li> is rather similar to
>>> r.le, so you should
>>> not have major problems.
>>> All the best.
>>> pc
>>> martin.besta at googlemail.com <mailto:martin.besta at googlemail.com> ha
>>> scritto:
>>> > Hi Paolo,
>>> > thank for your advice. I will try it. Now I am using Grass 6.2.1
>>> but module r.li <http://r.li> seems to be very important for my
>>> work. Can I have some more detailed dokumentation to r.li
>>> <http://r.li> (somethigs like for r.le)? Reference Manual for Grass
>>> 6.3. I already have.
>>> > Thanks
>>> > Martin
>>> > Paolo Cavallini wrote:
>>> >> have you tried r.li <http://r.li>? if it can solve your problem,
>>> it will probably do
>>> >> faster and in a more flexible way.
>>> >> pc
>>> >> Martin_Besta ha scritto:
>>> >>> Hi,
>>> >>> I have some problem with r.le.pixel. When I am trying to use this
>>> modul,
>>> >>> with my raster layer as background and another raster layer as
>>> sampling
>>> >>> area
>>> >>> (ca. 207 squares, 300x300m). Resolution of both layers is 1m, the
>>> program
>>> >>> after few minutes computing prints error: "G_calloc: out of memory
>>> >>> r.le.pixel is working..."
>>> >>> >From this time happend nothing more. I had take a look in System
>>> monitor
>>> > and
>>> >>> system memory is during calculation enough. Another module like
>>> r.le.pach
>>> >>> does work correct with the same dataset.
>>> >>> Thanks
>>> >>> Martin
>>> >> Paolo Cavallini, see: http://www.faunalia.it/pc
>>> >> _______________________________________________
>>> >> grassuser mailing list
>>> >> grassuser at grass.itc.it <mailto:grassuser at grass.itc.it>
>>> >> http://grass.itc.it/mailman/listinfo/grassuser
>>> > Quoted from:
>>> http://www.nabble.com/r.le-Problem-tf4220376.html#a12006425
>>> <http://www.nabble.com/r.le-Problem-tf4220376.html#a12006425>
