[GRASS-user] Looking for a Grass equivalent to
ESRI'sFocalmean(grid, ANNULUS, irad, orad)
Moskovitz, Bob
Bob.Moskovitz at conservation.ca.gov
Fri Aug 31 20:15:52 EDT 2007
Hi Glynn,
I was just looking at the CVS version of r.neighbors but didn't see where I can specify use an arbitrary neighbourhood shape unless it has something to do with the weight=string option. Unfortunately the documentation doesn't mention how to use it.
So, with r.neighbors, how would I annulus shape neighbourhood shape?
Thanks for your help!
Bob
Bob Moskovitz
Seismic Hazard Zonation Project
California Geological Survey
http://gmw.consrv.ca.gov/shmp
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
-----Original Message-----
From: Glynn Clements [mailto:glynn at gclements.plus.com]
Sent: Wednesday, August 29, 2007 7:21 PM
To: dylan.beaudette at gmail.com
Cc: grassuser at grass.itc.it; Moskovitz, Bob
Subject: Re: [GRASS-user] Looking for a Grass equivalent to
Dylan Beaudette wrote:
> not sure if there is any simple way to compute the neighborhood stats via an
> annulus shape, but you can use r.neighbors for a rectangular window.
The current CVS version of r.neighbors allows the use of an arbitrary
neighbourhood shape, as well as per-neighbor weights.
