[GRASS-user] Qgis per Windows: problemi con r.out.gdal
G. Allegri
giohappy at gmail.com
Sat Dec 1 07:56:52 EST 2007
I didn't think it was such a hard task to export a geotiff...
I've tried with the aspect from spearfish, trying to keep the decimal
values (FCELL), but nothing to do...
I'll wait for Grass 6.3 to be packaged.
2007/12/1, Markus Neteler <nseteler at fbk.eu>:
> G. Allegri wrote:
> > Hi Markus,
> > the pc I was using has Qgis 0.9.0.26 for Windows.
> > The raised error is
> > "ERROR 6: SetColorTable only supported for Byte or UInt16 bads in Tiff
> > format".
> > I get the same with r.out.gdal from Grass on my Ubuntu.
> As mentioned, I have fixed this recently:
> http://www.nabble.com/Re%3A-new-r.out.gdal-fails-to-preserve-8bit-color-p13860630.html
> G. Allegri wrote:
> > The resulting tiff appears uncorrect, with lot of blank areas...
> > This is what I get in coth cases:
> > http://www.geospatial.it/allegri/img/aspect_out.JPG
> > If I try with r.out.tiff it alerts me that decimal values will be
> > rounded to integer values, but the otuput seams correct...
> "Just" get a fresh GRASS 6.3 version (or the upcoming QGIS 0.9.1).
> ciao
> Markus
> View this message in context: http://www.nabble.com/Qgis-per-Windows%3A-problemi-con-r.out.gdal-tf4923752.html#a14104820
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
