[GRASS-user] Qgis per Windows: problemi con r.out.gdal
Markus Neteler
neteler at fbk.eu
Sat Dec 1 07:40:53 EST 2007
G. Allegri wrote:
> Hi Markus,
> the pc I was using has Qgis 0.9.0.26 for Windows.
> The raised error is
> "ERROR 6: SetColorTable only supported for Byte or UInt16 bads in Tiff
> format".
> I get the same with r.out.gdal from Grass on my Ubuntu.
As mentioned, I have fixed this recently:
http://www.nabble.com/Re%3A-new-r.out.gdal-fails-to-preserve-8bit-color-p13860630.html
G. Allegri wrote:
> The resulting tiff appears uncorrect, with lot of blank areas...
> This is what I get in coth cases:
> http://www.geospatial.it/allegri/img/aspect_out.JPG
> If I try with r.out.tiff it alerts me that decimal values will be
> rounded to integer values, but the otuput seams correct...
"Just" get a fresh GRASS 6.3 version (or the upcoming QGIS 0.9.1).
ciao
Markus
View this message in context: http://www.nabble.com/Qgis-per-Windows%3A-problemi-con-r.out.gdal-tf4923752.html#a14104820
Sent from the Grass - Users mailing list archive at Nabble.com.
