[GRASS-user] 3D graphics, two problems
Tomas Lanczos
lanczos at t-zones.sk
Sat Dec 1 12:45:45 EST 2007
I forgot the attachment, sorry.
Tomas Lanczos wrote:
> I have two questions regarding 3D rasters:
> 1. is there any rule of thumb for generating 3D rasters by v.vol.rst?
> The 3D raster represented by a cross section on the picture (see the
> attachment) is generated from 2D vectors layered each 250 m in interval
> -500 to -6000 below sea level. in the central part ther is apparent a
> strong oscillation, the outer part is segmentated. How can I avoid those
> artifacts changing settings (npmin > 500 is causing segfaults) ?
> 2. Using nviz the 3D raster is allways visualised above 0 m a.s.l,
> however all is below see level (as I explained above). The raster
> surface is visualised correctly, it should penetrate the 3D raster. Am I
> doing something wrong, or is it a bug?
> Many thnx in advance and regards
> Tomas
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20071201/8925ef5a/2d_3d-0001.png
