[GRASS-user] Correction of terrain effects for MODIS data?
Markus Neteler
neteler at fbk.eu
Sat Dec 1 15:54:28 EST 2007
Hi Nikos,
do you use
MODIS/Terra Surface Reflectance Daily L2G Global 250m SIN Grid V005
http://edcdaac.usgs.gov/modis/mod09gqv5.asp
MODIS/Aqua Surface Reflectance Daily L2G Global 250m SIN Grid V005
http://edcdaac.usgs.gov/modis/myd09gqv5.asp
Did you check the ATBD08 (Algorithm Technical Background Document)?
http://modis.gsfc.nasa.gov/data/atbd/atbd_mod08.pdf
But indeed - it doesn't seem to mention it.
here maybe some pointers:
http://scholar.google.com/scholar?q=modis+terrain+correction&hl=en&lr=&scoring=r&as_ylo=2002
Markus
Nikos Alexandris wrote:
> Hi!
> Will this approach enable a correction for terrain as well? I don't see
> how I can incorporate elevation data or anything relevant.
> I used the cosine correction approach which is described in GRASS-GIS in
> order to correct a MODIS image. But the result is over-corrected (!) as
> mentioned also in the book.
> I am looking for a practical approach in order to minimize terrain
> effects in a MODIS NIR surface reflectance acquisition. The area in
> which I am interested to visually identify the land cover, is
> mountainous. So any correction would be of great importance.
> Thank you in advance.
>> > I tried to follow the example for correction of terrain effects in a
>> MODIS
>> > surface reflectance NIR band
>> > (...as far as I know, MODIS surface reflectance imagery is only
>> corrected
>> > for atmospheric effects).
>> > I don't get the desired results... The output is too bright from what
>> one
>> > would expect it to be.
>> > Any recommendations?
>> I've never used it for MODIS, but you could try i.landsat.rgb to see if
>> that
>> helps. (it wants three 0-255 bands, it doesn't care about it being
>> LANDSAT or
>> not)
>> Hamish
>> ____________________________________________________________________________________
>> Never miss a thing. Make Yahoo your home page.
>> http://www.yahoo.com/r/hs
> Nikos Alexandris
> Department of Remote Sensing & Landscape Information Systems
> Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University
> Freiburg
> Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype:
> Nikos.Alexandris
> Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/Correction-of-terrain-effects-for-MODIS-data--tf4924201.html#a14109516
Sent from the Grass - Users mailing list archive at Nabble.com.
