[GRASS-user] Correction of terrain effects for MODIS data?
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sat Dec 1 22:14:26 EST 2007
Hello Jose!
Thank you for your clarifications.
Jose Gomez-Dans wrote:
> Hi,
> On Saturday 01 December 2007 21:11:28 Nikos Alexandris wrote:
>> > Did you check the ATBD08 (Algorithm Technical Background Document)?
>> > http://modis.gsfc.nasa.gov/data/atbd/atbd_mod08.pdf
>> > But indeed - it doesn't seem to mention it.
>> I ve read almost every line from the MODIS algorithm.
>> There seems to be an attempt to couple BRDF but no DEM is incorporated
>> in the approach.
> That's two different things altogether. Atmospheric correction tries to
> minimise the effects of the... well, atmosphere :) For that, it does need
> an
> idea of the angular reflectance properties of the surface (or assume
> something). In order to bring this into the algorithm, the BRDF (the
> variation of the reflectance as a function of illumination and viewing
> geometry) is used. Apart from the fact that the correction needs to take
> into
> account the width of the atmosphere (and hence needs an estimation of
> height), terrain is not a (major) issue for this correction.
> "I just mentioned the BRDF to emphasize that there is no link to any
> terrain parameters or to a topographic correction within the description
> of the algorithm (ATBD). And it is understandable since it is mainly an
> atmospheric correction algorithm."
> I think your problem comes to correct the variations in reflectance of the
> terrain in different images. This is the expected behaviour: in areas with
> high relief, you are looking at an interesting BRDF function, and small
> changes in illumination/viewing geometry will be greater than in flat
> terrain
> (which is more Lambertian-like).
> "Here it is interesting, indeed!"
> The good news is that you can use the BRDF
> product to ensure a constant illumination/viewing geometry for all your
> data.
> Using this does away with the geometry of acquisition variations, and
> depending on your terrain relief, you can choose the most optimal setup
> (you
> just work out $\rho$ from the kernel parameter estimates in MOD43
> product).
> So I will look for it... MOD43 (?). What is $\rho\$ exactly?
> Anyway, don't bother to reply to this question if it is explained on the
> web (for MOD43).
> Cheers,
> José
> Thank you for your time.
> Nikos.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/Correction-of-terrain-effects-for-MODIS-data--tf4924201.html#a14112242
Sent from the Grass - Users mailing list archive at Nabble.com.
