[GRASS-user] Correction of terrain effects for MODIS data?
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sat Dec 1 22:19:30 EST 2007
(...I have to stop using nabble for posting -- it doesn't seem to work
very well -- Sorry for reposting)
Hello Jose!
Thank you for your clarifications.
So I will look for it... MOD43 (?). What is $\rho\$ exactly?
Anyway, don't bother to reply to this question if it is explained on the
web (for MOD43).
Thank you for your time.
Nikos.
On Sat, 2007-12-01 at 21:54 +0000, José Gómez-Dans wrote:
> Hi,
> On Saturday 01 December 2007 21:11:28 Nikos Alexandris wrote:
> > > Did you check the ATBD08 (Algorithm Technical Background Document)?
> > > http://modis.gsfc.nasa.gov/data/atbd/atbd_mod08.pdf
> > > But indeed - it doesn't seem to mention it.
> > I ve read almost every line from the MODIS algorithm.
> > There seems to be an attempt to couple BRDF but no DEM is incorporated
> > in the approach.
> That's two different things altogether. Atmospheric correction tries to
> minimise the effects of the... well, atmosphere :) For that, it does need an
> idea of the angular reflectance properties of the surface (or assume
> something). In order to bring this into the algorithm, the BRDF (the
> variation of the reflectance as a function of illumination and viewing
> geometry) is used. Apart from the fact that the correction needs to take into
> account the width of the atmosphere (and hence needs an estimation of
> height), terrain is not a (major) issue for this correction.
> I think your problem comes to correct the variations in reflectance of the
> terrain in different images. This is the expected behaviour: in areas with
> high relief, you are looking at an interesting BRDF function, and small
> changes in illumination/viewing geometry will be greater than in flat terrain
> (which is more Lambertian-like). The good news is that you can use the BRDF
> product to ensure a constant illumination/viewing geometry for all your data.
> Using this does away with the geometry of acquisition variations, and
> depending on your terrain relief, you can choose the most optimal setup (you
> just work out $\rho$ from the kernel parameter estimates in MOD43 product).
> Cheers,
> José
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20071202/e2ccf321/attachment.bin
