[GRASS-user] GRASS6.2.1+QGIS0.9_db.connect
Salvator*eL*arosa
s_larosa at libero.it
Sun Dec 2 16:03:10 EST 2007
Markus Neteler wrote:
> The last two lines should be
> schema:
> group:
> Then it will work (best is to use db.connect for such things).
> Markus
Thanks,
I solved by the suggestion of Jonathan!
I have remove the last two lines in VAR and now work fine.
I tried again by db.connect, but without success!
I don't know!
Bye.
View this message in context: http://www.nabble.com/GRASS6.2.1%2BQGIS0.9_db.connect-tf4928891.html#a14119989
Sent from the Grass - Users mailing list archive at Nabble.com.
