[GRASS-user] Re: GRASS and DB, can I view VIEWS?
Moritz Lennert
mlennert at club.worldonline.be
Mon Dec 3 02:27:43 EST 2007
Georg Lösel (privat) wrote:
> Hi all,
> when I connect GRASS with PG I can alter the table (create new columns
> and alter data) and view these changes with grass.
> It is possible to create a VIEW in PG and connect the results with grass
> (without PostGIS!) ??
> My thoughts are these: if I want create a VIEW it must have an different
> name to the table, which is connectet with grass. And by this the view
> can't get in contact??
> I know I can alter the table and add information by this way to the
> geometry, but when I could view an VIEW it would be much smarter!
> Any ideas?
Yes you can connect a map to a view, just as you would connect it to a
table, using v.db.connect.
Moritz
