[GRASS-user] setting output nodata values in grass
Jamie Adams
dickeya at gmail.com
Tue Dec 4 15:09:01 EST 2007
Hello all,
I've been processing quite a bit of terrain data in GRASS and am having an
issue with output nodata values.. Is there anyway to set the output nodata
value when exporting a raster?
I use r.in.xyz to load gridded data, and then export it to GTiff using
r.out.gdal. The output file ends up with a float for null areas, something
like "NoData Value=-9.99999993381581e+36". I'd like to set it too something
simple like "-9999". I can use "r.null map=blah null=-9999", but then the
metadata "NoData" flag doesn't get set.
Is there a way to specify a specific nodata value, either for internal
storage, or as a metaopt for r.out.gdal? I'm trying to get the import /
export pipeline down to the least amount of steps possible.
Thanks,
Jamie
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071204/c746e63f/attachment.html
