[GRASS-user] Problems with v.external
Andreas Neumann
a.neumann at carto.net
Wed Dec 5 01:57:26 EST 2007
yes, PostgreSQL works in ogr. I also use it to import Interlis data to
Postgis.
Supported Formats:
-> "ESRI Shapefile" (read/write)
-> "MapInfo File" (read/write)
-> "UK .NTF" (readonly)
-> "SDTS" (readonly)
-> "TIGER" (read/write)
-> "S57" (read/write)
-> "DGN" (read/write)
-> "VRT" (readonly)
-> "AVCBin" (readonly)
-> "REC" (readonly)
-> "Memory" (read/write)
-> "CSV" (read/write)
-> "GML" (read/write)
-> "KML" (read/write)
-> "Interlis 1" (read/write)
-> "Interlis 2" (read/write)
-> "PostgreSQL" (read/write)
-> "GRASS" (readonly)
Seems to be another problem. Maybe with the quotes ...
Andreas
> hi Andreas,
> it seems to work here. Could it be that your OGR installation is
> not compiled with PG support?
> ogrinfo --formats
> tells you.
> Markus
> Andreas Neumann-7 wrote:
>> Hello,
>> I am trying to use postgis datasets read-only using v.external. However,
>> I
>> am having problems. Here is my command:
>> v.external dsn="PG:host=localhost dbname=uster user=an password=mypw"
>> layer=natur.naturnahe_gaerten output=gaerten
>> And here is my error message:
>> Sorry, <dbname> is not a valid parameter
>> Sorry, <user> is not a valid parameter
>> Sorry, <password> is not a valid parameter
>> I expected to run into problems with schemas, maybe, but not with the
>> login. What am I doing wrong in the dsn parameters?
>> Thanks for any hints,
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
>> Email: a.neumann at carto.net, Web:
>> * http://www.carto.net/ (Carto and SVG resources)
>> * http://www.carto.net/neumann/ (personal page)
>> * http://www.svgopen.org/ (SVG Open Conference)
>> * http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
> http://www.nabble.com/Problems-with-v.external-tf4944319.html#a14159258
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Andreas Neumann
