[GRASS-user] r.regression.line... differences with regression
function LINEST in openoffice.org-calc (?)
nikos.alexandris at felis.uni-freiburg.de
Tue Dec 4 22:00:38 EST 2007
I have submitted some comments upon the documentation of
the "r.regression.line" script in
http://wald.intevation.org/tracker/?func=detail&aid=552&group_id=21&atid=207
Now I have 2 questions.
Apologies if I miss some obvious things but I am confused!
Here it goes:
1. I don't understand why (in lines 84 and 85 in the
r.regression.line script) "sumsqX=sumsqX/tot" and
"sumsqY=sumsqY/tot" ?
2. I can't understand the differences in the following... :
I created two raster maps with the same MASK, each
containing only 6 pixels with the following values:
mapA: 326 641 1336 2020 3197 3484
mapB: 432 850 931 1956 2582 2622
For mapA "r.univar" gives:
n: 6
minimum: 326
maximum: 3484
range: 3158
mean: 1834
mean of absolute values: 1834
standard deviation: 1194.44
variance: 1.4267e+06
variation coefficient: 65.1278 %
sum: 11004)
For mapB... :
n: 6
minimum: 432
maximum: 2622
range: 2190
mean: 1562.17
mean of absolute values: 1562.17
standard deviation: 866.145
variance: 750207
variation coefficient: 55.4451 %
sum: 9373)
In openoffice calc (some of) the respective results are:
For mapA:
MIN: 326
MAX: 3484
AVERAGE: 1834
STDEV: 1308,45
VAR: 1,71E+06
SUM: 11004
For mapB:
MIN: 432
MAX: 2622
AVERAGE: 156217
STDEV: 948,81
VAR: 9,00E+05
SUM: 9373
Based on r.regression.line I get
for map1=mapA and map2=mapB:
a b R N F medX sdX medY sdY
0.000458151 0.809242 0.99157 1021726 -0.98321 0.01077
5.3038 0.00917369 4.32854
and
for map1=mapB and map2=mapB:
-0.000375823 1.21498 0.99157 1021726 -0.98321 0.00917369
4.32854 0.01077 5.3038
"R" is Pearson's correlation coefficient (as correctly
defined in the script "r.regression.line" in line 83 but
wrongly expressed as "sumXY - sumX*sumY/tot" in the
print-out in line 101).
In openoffice-calc I get for these:
MapA MapB
326 432 1,350792 Slope m
641 850 0,138835 standard error of the slope
1336 931 0,959458 RSQ (Square of "r")
2020 1956 94,662802 4,000000 F value from the variance
analysis std error of regression for Y
3197 2582 8213134,001379 sum of squared deviation of
estimated Y values from their linear mean
3484 2622
or
MapB MapB
432 326 0,710293 Slope m
850 641 0,073004 standard error of the slope
931 1336 0,959458 RSQ
1956 2020 94,662802 4,000000 F value from the variance
2582 3197 4318750,949062 sum of squared deviation of
2622 3484
(How is really r.regression.line functioning? Trying to
interpret the script is not that easy for me since I lack
of some basics in scripting)
Thank you,
Nikos.
