[GRASS-user] r.regression.line... differences with regression
function LINEST in openoffice.org-calc (?)
Markus Neteler
neteler at fbk.eu
Wed Dec 5 03:30:49 EST 2007
My suggestion is again to rewrite it a C program (not sure, based
on r.univar code?). I found a couple of bugs in the script and I am
(as you) not sure that it does what it promises to do).
Markus
Nikos Alexandris wrote:
> I have submitted some comments upon the documentation of
> the "r.regression.line" script in
> http://wald.intevation.org/tracker/?func=detail&aid=552&group_id=21&atid=207
> Now I have 2 questions.
> Apologies if I miss some obvious things but I am confused!
> Here it goes:
> 1. I don't understand why (in lines 84 and 85 in the
> r.regression.line script) "sumsqX=sumsqX/tot" and
> "sumsqY=sumsqY/tot" ?
> 2. I can't understand the differences in the following... :
> I created two raster maps with the same MASK, each
> containing only 6 pixels with the following values:
> mapA: 326 641 1336 2020 3197 3484
> mapB: 432 850 931 1956 2582 2622
> For mapA "r.univar" gives:
> n: 6
> minimum: 326
> maximum: 3484
> range: 3158
> mean: 1834
> mean of absolute values: 1834
> standard deviation: 1194.44
> variance: 1.4267e+06
> variation coefficient: 65.1278 %
> sum: 11004)
> For mapB... :
> n: 6
> minimum: 432
> maximum: 2622
> range: 2190
> mean: 1562.17
> mean of absolute values: 1562.17
> standard deviation: 866.145
> variance: 750207
> variation coefficient: 55.4451 %
> sum: 9373)
> In openoffice calc (some of) the respective results are:
> For mapA:
> MIN: 326
> MAX: 3484
> AVERAGE: 1834
> STDEV: 1308,45
> VAR: 1,71E+06
> SUM: 11004
> For mapB:
> MIN: 432
> MAX: 2622
> AVERAGE: 156217
> STDEV: 948,81
> VAR: 9,00E+05
> SUM: 9373
> Based on r.regression.line I get
> for map1=mapA and map2=mapB:
> a b R N F medX sdX medY sdY
> 0.000458151 0.809242 0.99157 1021726 -0.98321 0.01077
> 5.3038 0.00917369 4.32854
> and
> for map1=mapB and map2=mapB:
> -0.000375823 1.21498 0.99157 1021726 -0.98321 0.00917369
> 4.32854 0.01077 5.3038
> "R" is Pearson's correlation coefficient (as correctly
> defined in the script "r.regression.line" in line 83 but
> wrongly expressed as "sumXY - sumX*sumY/tot" in the
> print-out in line 101).
> In openoffice-calc I get for these:
> MapA MapB
> 326 432 1,350792 Slope m
> 641 850 0,138835 standard error of the slope
> 1336 931 0,959458 RSQ (Square of "r")
> 2020 1956 94,662802 4,000000 F value from the variance
> analysis std error of regression for Y
> 3197 2582 8213134,001379 sum of squared deviation of
> estimated Y values from their linear mean
> 3484 2622
> or
> MapB MapB
> 432 326 0,710293 Slope m
> 850 641 0,073004 standard error of the slope
> 931 1336 0,959458 RSQ
> 1956 2020 94,662802 4,000000 F value from the variance
> 2582 3197 4318750,949062 sum of squared deviation of
> 2622 3484
> (How is really r.regression.line functioning? Trying to
> interpret the script is not that easy for me since I lack
> of some basics in scripting)
> Thank you,
> Nikos.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/Problems-with-v.external-tf4944319.html#a14167166
Sent from the Grass - Users mailing list archive at Nabble.com.
