[GRASS-user] any tips/advice for workign with MODIS data?
Ivan Shmakov
oneingray at gmail.com
Thu Dec 6 03:43:33 EST 2007
>>>>> mhall at berkeley.edu writes:
> Hi,
> I've been trying for 2 or 3 days now to get some nice looking images
> out of MODIS TERRA/AQUA 500m land products (ie 7 bands). I've seen
> the screen shots and see the quality of the images that can be
> obtained--but at best I some very faded/obscured images. I've loaded
> the data into GRASS using HEGTool to convert the HDF file to separate
> bands. I've then loaded that and tired combining Bands 143 (RGB)
> using r.composite. I've tried using r.colors' standard grey scale
> and grey.eq before making the composite image. My values for the
> images ranges from -28672
I guess it may be a fill (``null'') value of the source data
set. Try to eliminate it with, e. g.:
$ r.null map=BAND setnull=-28672
and check the range afterwards. You may eliminate HEG's own
fill value as well with $ ... setnull=0.
> to approx. 9000 .
> I've tried rescaling the data to get it between 0 and 255, and the
> resulting image quality is equally bad.
> Any suggestions on what to try next?
In the ``Tutorial on Producing MODIS True Color Images'' [1],
authors suggest a table to be used for translating MODIS
reflectances into RGB values. You may apply this table to each
of the bands (via $ r.colors ... color=rules) prior to using
`r.composite'. IIRC, the result was about of the same quality
as the example in the tutorual when I've last tried that.
> I've checked the data out in other programs that are in other
> research groups and the data makes nice RGB images--so nothing wrong
> with the source data.
PS. May be a wiki [2] page for MODIS-related issues?
[1] ftp://ftp.ssec.wisc.edu/pub/IMAPP/MODIS/TrueColor/
[2] http://grass.gdf-hannover.de/wiki/
