[GRASS-user] Inverse PCA in GRASS
Venkatesh Raghavan
raghavan at media.osaka-cu.ac.jp
Thu Dec 6 22:23:40 EST 2007
Michael and Dylan,
Thanks for the response.
The image fusion method that we are trying to implement on GRASS
is briefly described in the paper below and also quite a few
others that I have skimmed through.
Multisensor image fusion in remote sensing: concepts, methods
and applications by POHL and VAN GENDEREN
http://www.cnr.berkeley.edu/~bingxu/UU/spatial/Readings/Pohl1998IJRS.pdf
I had also not heard of Inverse PCA before and was thinking
the the method suggested by Dylan would be adequate.
But, there seems to be more to it than I can comprehend at
this moment, so I am trying by doing some excersise on
PCA based image fusion in GRASS. Will try to look into
the algorithm suggested by Michael too.
Kind regards
Venka
Michael Perdue wrote:
> Venka,
> I think what your asking is if anyone knows how to apply the
> transformation matrix that was used to derive you pca components in
> reverse to get back to the original coordinate system. Something like
> what is done in a decorrelation stretch?
> Hopefully someone more knowledgeable than I can elaborate, but the
> general idea is as follows;
> if the i.pca is capable of divulging the eigenvectors, you can use
> r.mapcalc to apply them in reverse. else;
> r.covar -> m.eigensystem -> mapcalc -> "do something with your principal
> components" -> mapcalc (inverse rotation) -> "original coordinate system"
> You can take a look at the bottom of the r.covar page for more info. The
> big "if" is on the status of m.eigensystem. I tried the link to the
> manual page and it is broken so I'm unsure of it's status.
> Cheers,
> Mike
> On 6-Dec-07, at 9:05 AM, Venkatesh Raghavan wrote:
>> Dear All,
>> Commonly described method for image fusion in
>> in several publications involves inverse PCA transform
>> to get the new R,G,B bands of multispectral image from
>> the principle components.
>> Does any of you know a script or an algorithm to implement
>> inverse PCA in GRASS?
>> Thanks in advance.
>> Venka
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
