[GRASS-user] shading
Raffaele Morelli
raffaele.morelli at gmail.com
Fri Dec 7 03:46:44 EST 2007
2007/12/7, Malm Paul <paul.malm at saabgroup.com>:
> Hi,
> I've imported a dted file and are now trying to create a shaded relief of
> it. I entered the scalefactor for converting hor units to elevation units =
> 1.
> The resul was a rasterfile with about 1000 times lower resolution, the I
> changed scale factor to 0.002, but the result was the same.
> How can I create a nice relief, I don't mind if the res gets half of the
> original but this....
> I've installed Wingrass6_3_cvs20071818.zip
> Thanks in advance for all suggestions!
> /Paul
did you set region resolution using g.region res=xx?
r.shaded.relief will produce a raster with the current resolution (the one
you get with g.region -p)
raffaele
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071207/cd396fbb/attachment.html
