[GRASS-user] wanted: location parameters for modis import
Ivan Shmakov oneingray at gmail.com
Mon Dec 10 21:13:44 EST 2007
>>>>> Florian Kindl <florian.kindl at uibk.ac.at> writes:
 > I tried to import this image to GRASS GIS:
 > http://rapidfire.sci.gsfc.nasa.gov/gallery/?2003239-0827/
 > If you follow the "more info" link you'll see that the projection is
 > soemthing like a Lambert Azimuthal (equal area?) aver a sphere, not
 > an ellipsoid.
        There's a hack mentioned at [1], which sometimes helps to get
        MODIS L3 data to work with GDAL.
 > Additionally, it's rotated.
 > I didn't manage to set up a location to import the file into with
 > these parameters. Does anyone have an advice on this?
 > r.in.gdal can't import the file directly, as it's rotated.  I tried
 > gdalwarp to rotate the file by the information in its .jgw
 > file. r.in.gdal will then import the file but the problem of
 > location steup stays.
 > I want the image to end up in an UTM33-location, so the import
 > location has to be set up correctly for r.proj to perform nicely.
        Currently, you'll probably need to use `gdalwarp' (as suggested
        in [1]) to reproject the image, since GRASS (or PROJ.4) seems to
        lack the support for the ``WGS84 datum + spherical projection''
        combination.
        I guess, PROJ 4.6.0 will support combining any datum with any
        projection.  It may cause GRASS to support the exact projections
        used by MODIS L3 data.
[1] http://trac.osgeo.org/gdal/ticket/1239
