[GRASS-user] grass
Jachym Cepicky
jachym.cepicky at gmail.com
Tue Dec 11 03:05:29 EST 2007
that is not an error - you just did not calculate anything, because of
"WARNING: 2 points of given category missing"
are you sure, there are points with categories 1 and 2 in your input
file?
j
ec.jkd at tpcsed.com píše v Po 10. 12. 2007 v 15:15 +0530:
> hi,
> while doing shortest path in grass i get the below error:
> echo "1 1 2" | v.net.path mydgn_net afcol=forward abcol=backward out=myp
> Building graph:
> Registering arcs ... 100%
> Flattening the graph ... done.
> Graph was built.
> WARNING: 8032 points without category (nfield: 2).
> WARNING: No point with category 1
> WARNING: No point with category 2
> Attributes:
> cat - path unique category assigned by module
> id - path id (read from input)
> fcat - from point category
> tcat - to point category
> sp - result status:
> 0 - OK, path found
> 1 - node is not reachable
> 2 - point of given category does not exist
> cost - travelling costs (on the network, not to/from network)
> fdist - the distance from first point to the network
> tdist - the distance from the network to second point
> Building topology ...
> 0 primitives registered
> 0 areas built
> 0 isles built
> Attaching islands:
> Attaching centroids: Topology was built.
> Number of nodes : 0
> Number of primitives: 0
> Number of points : 0
> Number of lines : 0
> Number of boundaries: 0
> Number of centroids : 0
> Number of areas : 0
> Number of isles : 0
> Kindly, assisty me with this
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20071211/ebcc4895/attachment.bin
