[GRASS-user] Re: Problem with d.vect
Etsushi Kato
ek.kato at gmail.com
Thu Dec 13 03:58:12 EST 2007
On Dec 10, 2007 8:49 PM, Etsushi Kato <ek.kato at gmail.com> wrote:
> When invoking "d.vect gshhs_f", a monitor window x0 suddenly closed
> With grass-6.2.2, it shows the map without problem. Curiously (?),
> intermediate resolution version (gshhs_i) displays fine even with
> grass-6.3cvs. Is there any know problem with d.vect in grass-6.3csv?
After some investigations, I think this may be a problem related
XDRIVER since drawing the vector data on PNG file works fine (using
"d.mon start=PNG"). There seems to be a socket problem with XDRIVER
on grass-6.3cvs.
> g.gisenv set=DEBUG=1
> d.mon x0
> d.vect gshhs_f
D1/1: display areas:
D1/1: Vect_Rewind(): name = gshhs_f
WARNING: Monitor <x0>: Caught SIGPIPE
GRASS 6.3.cvs (global_shoreline):\w > X connection to :0.0 broken
(explicit kill or server shutdown).
Any suggestion?
Cheers,
Etsushi Kato
