[GRASS-user] How to best access hundreds of orthophotos -- mapserver as WMS server?
Rainer M Krug Rainer.grass at krugs.de
Fri Dec 14 04:12:16 EST 2007
Jachym Cepicky wrote:
> Hi Rainer,
> Rainer M Krug píše v Pá 14. 12. 2007 v 09:22 +0200:
>> Hi
>> I have hundreds, probably thousands, of orthophotos which I would like
>> to access as easy as possible. They are in MrSid format, but I will
>> convert them to geotiff.
>> My problem is that it is sometimes quite difficult to find the one
>> covering the region I am working in and it involves quite some trial and
>> error to get the right one (which is time intensive and annoying...).
>> I thought about setting up mapserver as a WMS server, but I didn't
>> manage (might have to spend some m ore time on that). What I would like
>> to know:
>> 1) Is mapserver as WMS server the best solution or is there a more
>> effective one?
> IMHO yes - but I would advice WCS to you. WMS does render "map", where
> WCS returns raw data (coverage) to  you.
thanks for pointing that out - I will consider it. But can I access the
WCS server from GRASS and QGIS as well?
>> 2) If mapserver (WMS server) is the way to go - can somebody give me an
>> example .map file which is achieving that?
> Some example attached - but please, take it as skeleton. I do not
> expect, single line would stay untouched after you start to modify it.
I'll do my best - but is always eaier to understand what's going on when
having a template to start with.
> have a look at
> http://mapserver.gis.umn.edu/docs/reference/mapfile
> http://mapserver.gis.umn.edu/docs/howto/wcs_server
> http://mapserver.gis.umn.edu/docs/howto/tileindex
Thanks - I'll look at them as well.
>> 3) the whole layer is obviously in several single tiles - can mapserver
>> handle this as a single layer or do I( have to do something special?
> see the tileindex link above
>> Sorry for the slightly oftopic questions - but 1) should be ontopic.
>> Thanks
>> Rainer
> good luck :)
That sounds as if I would need it ...
> j
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
