[GRASS-user] How to best access hundreds of orthophotos --
mapserver as WMS server?
Hamish
hamish_b at yahoo.com
Fri Dec 14 19:24:54 EST 2007
> > Rainer Krug writes:
> >> I have hundreds, probably thousands, of orthophotos which I would
> >> like to access as easy as possible.
> >> My problem is that it is sometimes quite difficult to find the one
> >> covering the region I am working in and it involves quite some
> >> trial and error to get the right one (which is time intensive and
> >> annoying...).
an idea: write a little script to make a vector coversheet index.
maybe output that with the HTMLMAP driver for an interactive web brower
pull up.
I am not sure, but I think v.patch does not clean topology so overlap
may be ok. Also I am not sure about using v.edit to reasign a category
number. Also the "for MAP in ``" method would need to be changed if
there are thousands of maps?
this is just the idea. non functional...
# store current region
g.region save=old_region
# create new empty map
v.in.ascii -e out=map_index
v.db.addtable map_index columns="image varchar(128)"
i=0
for MAP in `g.mlist patt='ortho_*'` ; do
i=`expr $i + 1`
g.region rast="$MAP"
v.in.region out="${MAP}_box"
? v.edit to reset the region box centroid's cat to $i ?
# or a series of v.category del then add steps
# merge into master index
g.remove vect=map_index_old
g.rename vect=map_index,map_index_old
v.patch in=map_index_old,"${MAP}_box" out=map_index
# write map name to DB entry
v.db.update map_index column=image value="'$MAP'" where="cat = $i"
done
#reset to original region
g.region old_region
v.label map=map_index column=image
d.labels
#or
d.vect display=attr attrcol=image xref=center
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
