[GRASS-user] problem importing data from GNS
Markus Neteler neteler at fbk.eu
Sun Dec 16 13:07:52 EST 2007
the GNS format was changed. GRASS' v.in.gns was fixed for this in 6.2.2:
http://grass.itc.it/announces/announce_grass622.html
Please update (preferably to 6.2.3).
Markus
mohannbr wrote:
> Hi,
>     i use grass6.2.1 in fedora core 6.while trying to import data from GNS
> using the command ..
>    v.in.gns file=indata/uk/uk.txt vect=cities
>         i got the following warnings and error...
> WARNING: Unparsable LatLong value found: LAT
> WARNING: Unparsable LatLong value found: LONG
> Maximum input row length: 283
> Maximum number of columns: 26
> Minimum number of columns: 26
> ERROR: x column is not of number type
> ..the command is supposed to create an input  map cities which would be
> further required to process the data.Since i'm not able to get this input
> map done, i can't proceed with the processing part.please help in finding
> a soln..
View this message in context: http://www.nabble.com/problem-importing-data-from-GNS-tp14364049p14364216.html
Sent from the Grass - Users mailing list archive at Nabble.com.
