[GRASS-user] towgs84 datum parameters for "Hong Kong 1980"
Otto Dassau
otto.dassau at gmx.de
Mon Dec 17 04:55:20 EST 2007
Hi Nikos and Paul
thanks a lot for your help and notes. I will test the parameters and write back
then. Maybe then, we can add the datum parameters to grass svn.
Regards,
Otto
On Thu, 13 Dec 2007 13:51:17 +0000 (GMT)
Paul Kelly <paul-grass at stjohnspoint.co.uk> wrote:
> On Thu, 13 Dec 2007, Otto Dassau wrote:
> > Hi,
> > I need some help to add support for "Hong Kong 1980" datum in GRASS. I
> > have a wkt file with following information:
PROJCS["Hong_Kong_1980_Grid",GEOGCS["GCS_Hong_Kong_1980",DATUM["D_Hong_Kong_198
0",SPHEROID["International_1924",6378388.0,297.0]],PRIMEM["Greenwich",0.0],UNIT
["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["Fal
se_Easting",836694.05],PARAMETER["False_Northing",819069.8],PARAMETER["Central_
Meridian",114.1785555555556],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_
> > Of_Origin",22.31213333333334],UNIT["Meter",1.0]]
> > The datum D_Hong_Kong_1980 does not exist in GRASS yet. I found following
> > parameters and added them to the datum.table file:
> > # Hong Kong Datum 1980
> > hk80 "Hong_Kong_1980" international dx=-156 dy=-270 dz=-189
> > Now I am missing the Datum Transformation Parameters to add to the
> > datumtransform.table.
> Just to note that you do not necessarily need to add parameters to both
> datum.table and datumtransform.table. If dx=-156 dy=-270 dz=-189 are
> the only parameters you have, that is fine and they will be the only ones
> used. An entry in datumtransform.table is only needed if you have multiple
> sets of parameters for the datum, or if the only set you have available is
> not a 3-parameter set.
> Paul
