[GRASS-user] Res: grass-user Digest, Vol 20, Issue 38
Angelo Mansur Mendes
angelomansur at yahoo.com.br
Fri Dec 21 16:38:20 EST 2007
----- Mensagem original ----
De: "grass-user-request em lists.osgeo.org" <grass-user-request em lists.osgeo.org>
Para: grass-user em lists.osgeo.org
Enviadas: Segunda-feira, 17 de Dezembro de 2007 13:00:07
Assunto: grass-user Digest, Vol 20, Issue 38
Send grass-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/grass-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
grass-user-owner em lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."
Today's Topics:
1. Re: nan values by v.generalize (Hamish)
2. Re: How to best access hundreds of orthophotos -- mapserver
as WMS server? (Ivan Shmakov)
3. Re: How to best access hundreds of orthophotos -- mapserver
4. Re: towgs84 datum parameters for "Hong Kong 1980" (Otto Dassau)
5. UTM projection problems (mhall em berkeley.edu)
6. r.patch example in the manual (Craig Leat)
7. Re: r.patch example in the manual (Martin Landa)
8. Re: GRASS_HTML_BROWSER (Glynn Clements)
9. Re: Re: How to best access hundreds of orthophotos --
mapserver as WMS server? (Glynn Clements)
Message: 1
Date: Sun, 16 Dec 2007 15:46:47 -0800 (PST)
Subject: Re: [GRASS-user] nan values by v.generalize
To: Daniel Bundala <bundala em gmail.com>, Wolf Bergenheim
<wolf+grass em bergenheim.net>
Cc: grass-user em lists.osgeo.org
Message-ID: <128490.96785.qm em web45805.mail.sp1.yahoo.com>
Content-Type: text/plain; charset=iso-8859-1
Daniel Bundala wrote:
> > > As I mentioned in my previous post, a solution is to translate
> > > the corresponding points little bit.
> The patch is attached. Hope it works.
May I suggest replacing 1e-12 with GRASS_EPSILON? (defined in gis.h)
> === message truncated ===>
everyone, please do.
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Message: 2
Date: Mon, 17 Dec 2007 08:18:40 +0600
Subject: [GRASS-user] Re: How to best access hundreds of orthophotos
-- mapserver as WMS server?
To: grassuser em grass.itc.it
Cc: Ivan Shmakov <oneingray em gmail.com>
Message-ID: <m2r6hmjc73.fsf em cherry.siamics.int>
Content-Type: text/plain; charset=us-ascii
>>>>> Hamish <hamish_b em yahoo.com> writes:
>>> an idea: write a little script to make a vector coversheet index.
>>> I am not sure, but I think v.patch does not clean topology so
>>> overlap may be ok.
> Ivan:
>> Wouldn't it be better to save non-overlapping parts and an
>> intersection as separate polygons? A separate attribute will be
>> needed to store the list of IDs of the covering images.
> see overlapping polygon example at:
> http://grass.ibiblio.org/screenshots/vector.php
Thanks, I'll check it.
>>> # store current region
>>> g.region save=old_region
>> It makes me wonder each time I see such a fragile construct like
>> this, will GRASS ever support overriding the region
>> ``temporarily''? (E. g., via a command line argument, or an
>> environment variable.)
> there is, see GRASS_REGION and WIND_OVERRIDE shell variables:
> http://grass.ibiblio.org/grass63/manuals/html63_user/variables.html
This is exactly what I've asked for. Thanks!
> but saving & restoring g.region isn't need for this task, it is just
> being nice leaving the place as you found it. The script is not
> dependent on the starting region. And I fail to see how that's
> fragile?
Consider this script being interrupted in the middle (say, by
the user hitting ^C.) Will the region be restored?
> No more fragile than trusting anything else written to the disk.
It looks to me that the following will be much more robust:
export WIND_OVERRIDE=tmp_region
# no need to store current region
# g.region save=old_region
g.region rast="$MAP"
# no need to reset to original region, either
# g.region old_region
>> And, could there be something a bit more clever than storing the
>> region of the image as a vector feature?
> the user can get as complicated as they like..
>> A combination of downsampling, `r.mapcalc' (to obtain the fill mask),
>> and `r.contour', may be?
> r.contour is not so good for ortho photos or high resolution land use
> map with many small areas. But again, up to the user....
Actually, I meant using `r.contour' on the downsampled fill
mask. (Meanwhile, I've silently switched to my own needs, which
are about the satellite data.)
Message: 3
Date: Mon, 17 Dec 2007 08:28:06 +0600
To: grass-user em lists.osgeo.org
Message-ID: <m2mysajbrd.fsf em cherry.siamics.int>
>>>>> Dylan Beaudette <dylan.beaudette em gmail.com> writes:
>>> maybe output that with the HTMLMAP driver for an interactive web brower
>>> pull up.
>> region of the image as a vector feature? A combination of
>> downsampling, `r.mapcalc' (to obtain the fill mask), and
> Hi,
> What you are asking for is starting to sound like a Mapserver driven
> WMS.
Actually, I'm seeking for a some kind of cataloguing solution
for GRASS. However, setting up Mapserver is also on my TODO
list.
> Here is how I have dealt with this problem in the past:
> 5. create a very simple mapfile pointing to the tile index
> shapefile. I will work up an example and post it back
TIA.
> 6. fill in appropriate WMS metadata into the mapfile
> 7. use r.in.wms to import imagery into GRASS
> -or-
> 7. once GDAL 1.5 is released it will be possible to an r.in.gdal and
> point it to an XML file defining a WMS resource. A mini-script might
> be able to construct the XML file on the fly...
> Unfortunately you will still have to manage the images that are
> imported into GRASS with GRASS commands, unless you constantly
> overwrite a temporary set of files by always using the same names and
> the --o flag.
> Once you have mapserver setup WMS is quite fast and flexible - it
> will even project the data on the fly to other coordinate systems.
Yes, I know. (Though I hadn't succeed in getting it to show me
any rasters last time I've tried it; the software packages were
from Debian etch, if that matters.)
Message: 4
Date: Mon, 17 Dec 2007 10:55:20 +0100
Subject: Re: [GRASS-user] towgs84 datum parameters for "Hong Kong
1980"
To: Paul Kelly <paul-grass em stjohnspoint.co.uk>
Message-ID: <20071217105520.17c21bec em nature>
Content-Type: text/plain; charset=US-ASCII
Hi Nikos and Paul
thanks a lot for your help and notes. I will test the parameters and write back
then. Maybe then, we can add the datum parameters to grass svn.
Regards,
Otto
On Thu, 13 Dec 2007 13:51:17 +0000 (GMT)
Paul Kelly <paul-grass em stjohnspoint.co.uk> wrote:
> On Thu, 13 Dec 2007, Otto Dassau wrote:
> > Hi,
> > I need some help to add support for "Hong Kong 1980" datum in GRASS. I
> > have a wkt file with following information:
PROJCS["Hong_Kong_1980_Grid",GEOGCS["GCS_Hong_Kong_1980",DATUM["D_Hong_Kong_198
0",SPHEROID["International_1924",6378388.0,297.0]],PRIMEM["Greenwich",0.0],UNIT
["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["Fal
se_Easting",836694.05],PARAMETER["False_Northing",819069.8],PARAMETER["Central_
Meridian",114.1785555555556],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_
> > Of_Origin",22.31213333333334],UNIT["Meter",1.0]]
> > The datum D_Hong_Kong_1980 does not exist in GRASS yet. I found following
> > parameters and added them to the datum.table file:
> > # Hong Kong Datum 1980
> > hk80 "Hong_Kong_1980" international dx=-156 dy=-270 dz=-189
> > Now I am missing the Datum Transformation Parameters to add to the
> > datumtransform.table.
> Just to note that you do not necessarily need to add parameters to both
> datum.table and datumtransform.table. If dx=-156 dy=-270 dz=-189 are
> the only parameters you have, that is fine and they will be the only ones
> used. An entry in datumtransform.table is only needed if you have multiple
> sets of parameters for the datum, or if the only set you have available is
> not a 3-parameter set.
> Paul
Message: 5
Date: Mon, 17 Dec 2007 07:07:50 -0800 (PST)
Subject: [GRASS-user] UTM projection problems
Message-ID:
<1378.12.74.52.211.1197904070.squirrel em calmail.berkeley.edu>
Content-Type: text/plain;charset=iso-8859-1
I am using GRASS 6.2 on a Windows XP machine. Its the cygwin build. I
also access it from QGIS 8.1 for windows.
The problem I am noticing is reading in a satellite image (ASTER or
Landsat) and the projection and reference system I end up with. My
imagery is in Geotiff format. Reading the metadata files and the
projection info of the Geotiff of course lists the correct zone, etc.
When I load the image into GRASS via r.in.gdal and tell GRASS to create a
new location, I get a generic x,y system set-up and the UTM projection
zone is 0 (no matter where in the world I have my imagery, been tested on
several sets of images...). I go in and reset the projection, bt once I
exit GRASS, the projection defaults back. Oddly enough, the projection it
creates is consistent in terms of overlays, etc. And even odder, when I
import an image in lat-lon it creates that.
Any suggestions on what I am making a mess of?
Best, Mark Hall
Message: 6
Date: Mon, 17 Dec 2007 07:37:33 -0800 (PST)
Subject: [GRASS-user] r.patch example in the manual
Message-ID: <14372554.post em talk.nabble.com>
Hello List
I'm trying the r.patch example given in the manual for 6.3.0RC3 and there
appears to be a problem passing the output from g.mlist to g.region. So, in
fact, I haven't managed to try r.patch yet. I followed the example and this
is what I got back:
GRASS 6.3.0RC3 (msunduzi_lo31):~ > MAPS='g.mlist type=rast sep=,
pat="*.red"'
GRASS 6.3.0RC3 (msunduzi_lo31):~ > echo $MAPS
g.mlist type=rast sep=, pat="*.red"
GRASS 6.3.0RC3 (msunduzi_lo31):~ > g.region rast=$MAPS
Sorry, <type> is not a valid parameter
Sorry, <sep> is not a valid parameter
Sorry, <pat> is not a valid parameter
I guess I need to tell bash to evaluate MAPS rather than just expanding the
variable, but I am not sure how. Pointers are welcome...
Thanks
Craig.
View this message in context: http://www.nabble.com/r.patch-example-in-the-manual-tp14372554p14372554.html
Sent from the Grass - Users mailing list archive at Nabble.com.
Message: 7
Date: Mon, 17 Dec 2007 16:51:01 +0100
Subject: Re: [GRASS-user] r.patch example in the manual
To: "Craig Leat" <Craig em pid.co.za>
Message-ID:
<f8fe65c40712170751p4a06e4e4wc9c7f338ef444619 em mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
2007/12/17, Craig Leat <Craig em pid.co.za>:
> is what I got back:
> pat="*.red"'
Instead of ' use ` ...
MAPS=`g.mlist type=rast sep=, pat="*.red"`
Martin
Martin Landa <landa.martin em gmail.com> * http://gama.fsv.cvut.cz/~landa *
Message: 8
Date: Mon, 17 Dec 2007 17:05:01 +0000
Subject: Re: [GRASS-user] GRASS_HTML_BROWSER
To: Craig Leat <Craig em pid.co.za>
Message-ID: <18278.44093.56346.971962 em cerise.gclements.plus.com>
Craig Leat wrote:
> If I click: Help -> GRASS help on the tcl/tk gui, GRASS tries to launch
> konqueror when what I want is firefox. g.manual -i on the commandline gives
> me firefox. I have set GRASS_HTML_BROWSER in two places (see below), but I
> guess I still need to set the variable some place else?
> GRASS 6.3.0RC3 (msunduzi_lo31):~ > more .grass.bashrc
> export GRASS_HTML_BROWSER=firefox
> GRASS 6.3.0RC3 (msunduzi_lo31):~ > g.gisenv
> GISDBASE=/home/craig/GIS/grassdata
> MAPSET=sewer
> LOCATION_NAME=msunduzi_lo31
> GRASS_GUI=tcltk
> Any ideas on what I'm missing?
GRASS_HTML_BROWSER is an environment variable rather than a GRASS
variable, so setting it via g.gisenv won't help.
Also setting it in ~/.grass.bashrc will only affect the GRASS shell
and programs launched from it. If you have gis.m launched at startup,
it won't be affected.
You can set it in ~/.bash_profile (etc) to have it apply everywhere,
but that won't affect any shells which are already running. For an
existing shell, type "export GRASS_HTML_BROWSER=firefox" before
starting GRASS.
Glynn Clements <glynn em gclements.plus.com>
Message: 9
Date: Mon, 17 Dec 2007 17:09:44 +0000
Subject: Re: [GRASS-user] Re: How to best access hundreds of
orthophotos -- mapserver as WMS server?
To: Ivan Shmakov <oneingray em gmail.com>
Cc: grassuser em grass.itc.it
Message-ID: <18278.44376.912469.193779 em cerise.gclements.plus.com>
Ivan Shmakov wrote:
> > Also the "for MAP in ``" method would need to be changed if there are
> > thousands of maps?
> I don't think so. Since the `for' command is internal to the
> Shell, there's no command line to be passed to any other
> process, and so there're no command line length limits in force.
> Still, using COMMAND | while read VARN ; do ...; done looks more
> clean to me.
The while/read approach saves keeping the list of maps in memory. Once
upon a time, that might have mattered; with modern systems, you would
need millions of maps before it became an issue.
End of grass-user Digest, Vol 20, Issue 38
Abra sua conta no Yahoo! Mail, o único sem limite de espaço para armazenamento!
http://br.mail.yahoo.com/
-------------- Próxima Parte ----------
Um anexo em HTML foi limpo...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071221/cc9c2389/attachment-0001.html
