[GRASS-user] Trying to export a 3d Layer
Matthew Pulis
mpulis at gmail.com
Sat Dec 22 12:23:11 EST 2007
I did not create the layer myself. Downloaded it in the north Carolina
package that came out with Grass Book 3
Sent: Saturday, December 22, 2007 1:13 AM
To: Matthew Pulis
Cc: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Trying to export a 3d Layer
v.db.select tells you that you haven't an associated db tabel... Maybe
something wrong while creating your elev_contoru_3m layer?
Giovanni
2007/12/21, Matthew Pulis < mpulis at gmail.com <mailto:mpulis at gmail.com> >:
I am trying to export a contour layer to PostGIS / Shapefile / GML but to no
avail. The files I am trying to export are in GRASS Vector format, thus I am
using v.out.ogr. I am using the dataset found with the Grass Book Edition 3
(North Carolina). My layer is elev_contour_3m. I tried also to load the 10m
contour layer in the same dataset but got the same results, so I do not
think it is a problem of the vector files, but more of an exporting problem.
Any help how I can make this layer into a useable layer outside GRASS is
extremely appreciated!
I am taking this email to wish everyone on the list best wishes for
Christmas and New Year to you and your families :)
Matthew
I am supplying some info which might help you give me some tips how I can do
it.
GRASS 6.3.0RC1 (thesis):~/thesis_gis/thesis/yancho/vector/elev_contour_3m >
v.out.ascii elev_contour_3m format=standard | head -n 20
ORGANIZATION: NC OneMap
DIGIT DATE:
DIGIT NAME: helena
MAP NAME:
MAP DATE: Fri Mar 9 12:12:48 2007
MAP SCALE: 1
OTHER INFO:
ZONE: 0
MAP THRESH: 0.000000
VERTI:
L 309 1
644845.39132067 228495 58
644850.5257363 228485 58
644855 228476.80568172 58
v.db.select elev_contour_3m
DBMI-DBF driver error:
Table 'elev_contour_3m' doesn't exist.
Error in db_open_select_cursor()
v.info elev_contour_3m
| Layer: elev_contour_3m
| Mapset: yancho
| Database: /home/yancho/thesis_gis
| Title:
| Map scale: 1:1
| Map format: native
| Name of creator: helena
| Organization: NC OneMap
| Source date: Fri Mar 9 12:12:48 2007
| Number of lines: 3355 Number of islands: 0
And these are the output formats I tried :
v.out.ogr input=elev_contour_3m format=ESRI_Shapefile
dsn=/home/yancho/elevation.shp
WARNING: Vector map <elev_contour_3m> is 3D. Use format specific layer
creation options (parameter 'lco') to export in 3D rather than 2D
(default)
ERROR: Unable to describe table <elev_contour_3m>
v.out.ogr in=elev_contour_3m type=face dsn="PG:host=localhost dbname=thesis
user=usernamehere password=passhere" format=PostgreSQL lco="SHPT=ARCZ"
(default)
I tried also lco="DIM=3" but got same results.
_____
I am using the free version of SPAMfighter for private users.
It has removed 18742 spam emails to date.
Paying users do not have this message in their emails.
Try SPAMfighter <http://www.spamfighter.com/len> for free now!
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
_____
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071222/5d288d81/attachment.html
