[GRASS-user] Trying to export a 3d Layer
G. Allegri
giohappy at gmail.com
Fri Dec 21 19:13:05 EST 2007
v.db.select tells you that you haven't an associated db tabel... Maybe
something wrong while creating your elev_contoru_3m layer?
Giovanni
2007/12/21, Matthew Pulis <mpulis at gmail.com>:
> Hi,
> I am trying to export a contour layer to PostGIS / Shapefile / GML but to
> no avail. The files I am trying to export are in GRASS Vector format, thus I
> am using v.out.ogr. I am using the dataset found with the Grass Book
> Edition 3 (North Carolina). My layer is elev_contour_3m. I tried also to
> load the 10m contour layer in the same dataset but got the same results, so
> I do not think it is a problem of the vector files, but more of an exporting
> problem.
> Any help how I can make this layer into a useable layer outside GRASS is
> extremely appreciated!
> I am taking this email to wish everyone on the list best wishes for
> Christmas and New Year to you and your families :)
> Matthew
> I am supplying some info which might help you give me some tips how I can
> do it.
> GRASS 6.3.0RC1 (thesis):~/thesis_gis/thesis/yancho/vector/elev_contour_3m
> > v.out.ascii elev_contour_3m format=standard | head -n 20
> ORGANIZATION: NC OneMap
> DIGIT DATE:
> DIGIT NAME: helena
> MAP NAME:
> MAP DATE: Fri Mar 9 12:12:48 2007
> MAP SCALE: 1
> OTHER INFO:
> ZONE: 0
> MAP THRESH: 0.000000
> VERTI:
> L 309 1
> 644845.39132067 228495 58
> 644850.5257363 228485 58
> 644855 228476.80568172 58
> > v.db.select elev_contour_3m
> DBMI-DBF driver error:
> Table 'elev_contour_3m' doesn't exist.
> Error in db_open_select_cursor()
> > v.info elev_contour_3m
> | Layer:
> elev_contour_3m |
> | Mapset:
> yancho |
> | Location:
> thesis |
> | Database:
> /home/yancho/thesis_gis |
> Title: |
> | Map scale: 1:1
> | Map format:
> native |
> | Name of creator:
> helena |
> | Organization: NC OneMap
> | Source date: Fri Mar 9 12:12:48 2007
> | Number of lines: 3355 Number of islands:
> 0 |
> And these are the output formats I tried :
> > v.out.ogr input=elev_contour_3m format=ESRI_Shapefile
> dsn=/home/yancho/elevation.shp
> WARNING: Vector map <elev_contour_3m> is 3D. Use format specific layer
> creation options (parameter 'lco') to export in 3D rather than 2D
> (default)
> ERROR: Unable to describe table <elev_contour_3m>
> > v.out.ogr in=elev_contour_3m type=face dsn="PG:host=localhost
> dbname=thesis user=usernamehere password=passhere" format=PostgreSQL
> lco="SHPT=ARCZ"
> (default)
> I tried also lco="DIM=3" but got same results.
> I am using the free version of SPAMfighter for private users.
> It has removed 18742 spam emails to date.
> Paying users do not have this message in their emails.
> Try SPAMfighter <http://www.spamfighter.com/len> for free now!
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071222/9dda4f1a/attachment.html
