[GRASS-user] elevation values of watershed basins
Dylan Beaudette
dylan.beaudette at gmail.com
Mon Feb 5 16:45:48 EST 2007
On Thursday 01 February 2007 08:27, temiz wrote:
> Dylan Beaudette wrote:
> > On Wednesday 31 January 2007 05:14, Markus Neteler wrote:
> >> temiz wrote on 01/31/2007 06:53 PM:
> >>> hello
> >>> Can you make a suggestion about how I can find the highest and lowest
> >>> elevation points of all watershed basins
> >>> as vector points ?
> >>> I mean, I have watershed map as vector. I need it's table includes
> >>> like "cat", "highest elevation value", "lowest elevation value"
> >>> How can I do that ?
> >> If I understand your question correctly, you can do this easily with
> >> v.rast.stats
> >> Description:
> >> Calculates univariate statistics from a GRASS raster map based on
> >> vector objects
> >> The help page contains a similar example.
> >> cheers
> >> Markus
> > If you have problems with this approach (no reason to suspect problems),
> > I have found that 'starspan' coupled with GRASS to be an excellent
> > raster+vector reporting tool.
> > main idea:
> > start grass
> > starspan --vector location/mapset/vector/yourvector \
> > --raster location/mapset/cellhd/your_raster \
> > --stats output.csv min max avg mode (...)
> > Output is saved to a CSV file, not quite as nice as v.rast.stats saving
> > results back to the attribute table though... The nice thing about this
> > approach is that the raster and vector sources can be any GDAL-readable
> > data type. For example, I use starspan to compute raster statistics
> > within a given radius of a set of points. The raster files are all stored
> > in GRASS, and the points are stored in PostGIS.
> > Cheers,
> /*thank you
Hi Ahmet,
> /*I have never met */starspan so far. I am looking at its home page and
> it will certain to be very useful.
> I will work on it.
Be sure to, it is a simple compile from source code if you have both GDAL and
GEOS installed with their include files.
> As I see, you are a soil scientist, so you will understand me better.
:) possibly...
> The logic of my question is based on finding slopes' length as landslide
> susceptibility parameter ( I accept slope is waterhed area).
so: landslide susceptibility ~ f( slope length ) --> this is a simple
raster-based operation: calculate the upslope contributing area for each cell
of a DEM. Check the literature for ideas.
I am not entirely sure I understand what you are trying to do... Are you
trying to estimate a landslide potential for each watershed boundary polygon?
> Firstly, I used PostGis's extent function and got width and length of
> polygons (say watershed or landslide as polygon). But this
> polygon's longest dimension doesn't fit dimension in downslope
> direction, which is the slope length I am looking for. So, if I found
> max and min values of elevation of the polygons, I could calculate
> slopes' length.
This does not sound like a realistic solution, as the extent() function will
return a minimum bonding box -- which provides the maximum 'length'
and 'width' of some polygon, but not much useful information.
> /*v.rast.stats */gives max and min values of elevation of the polygons(
> /*v.rast.stats*/ has still been running for most 20 hours).
> maybe from these values I generate vector points containing min & max
> values .
Do you have a number of polygons, and the specifications for your DEM: cell
size, region size? You may have hit some upper boundary for v.rast.stats.
Starpan seems to scale very well, so you may not run into this problem.
> I will appreciate if you supply your ideas and recommendations
> regards
Sure. With a clearer statement of the problem, and some information on your
source data it may be possible to come up with a workable solution.
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
