[GRASS-user] elevation values of watershed basins
temiz temiz at deprem.gov.tr
Thu Feb 8 10:56:29 EST 2007
Dylan Beaudette wrote:
>>> On Wednesday 31 January 2007 05:14, Markus Neteler wrote:
>>>> temiz wrote on 01/31/2007 06:53 PM:
>>>>> hello
>>>>> Can you make a suggestion about how I can find the highest and lowest
>>>>> elevation points of all watershed basins
>>>>> as vector points ?
>>>>> I mean, I have watershed map as vector. I need it's table includes
>>>>> like "cat", "highest elevation value", "lowest elevation value"
>>>>> How can I do that ?
>>>> If I understand your question correctly, you can do this easily with
>>>> v.rast.stats
>>>> Description:
>>>>  Calculates univariate statistics from a GRASS raster map based on
>>>> vector objects
>>>> The help page contains a similar example.
>>>> cheers
>>>> Markus
>>> If you have problems with this approach (no reason to suspect problems),
>>> I have found that 'starspan' coupled with GRASS to be an excellent
>>> raster+vector reporting tool.
>>> main idea:
>>> start grass
>>> starspan --vector location/mapset/vector/yourvector \
>>> --raster location/mapset/cellhd/your_raster \
>>> --stats output.csv min max avg mode (...)
>>> Output is saved to a CSV file, not quite as nice as v.rast.stats saving
>>> results back to the attribute table though... The nice thing about this
>>> approach is that the raster and vector sources can be any GDAL-readable
>>> data type. For example, I use starspan to compute raster statistics
>>> within a given radius of a set of points. The raster files are all stored
>>> in GRASS, and the points are stored in PostGIS.
>>> Cheers,
>> /*thank you
> Hi Ahmet,
>> /*I have never met  */starspan so far. I am looking at its home page and
>> it will certain to be very useful.
>> I will work on it.
> Be sure to, it is a simple compile from source code if you have both GDAL and
> GEOS installed with their include files.
>> As I see, you are a soil scientist, so you will understand me better.
> :) possibly...
>> The logic of my question is based on finding slopes' length as landslide
>> susceptibility parameter ( I accept slope is waterhed area).
> so: landslide susceptibility ~ f( slope length ) --> this is a simple
> raster-based operation: calculate the upslope contributing area for each cell
> of a DEM. Check the literature for ideas.
> I am not entirely sure I understand what you are trying to do... Are you
> trying to estimate a landslide potential for each watershed boundary polygon?
     I am going to build the model using logistic regression ( in R - Stat).
      slope  length  is not only parameter.
     -- existing landslides are response variable
     -- rock type,slope angle, slope shape, aspect, slope length (**
??**)  are the explatory variables.
     I have already constructed all maps except slope length.
     I am going to use watershed basin as slope unit in one model. So
you are right, each watershed
     basin ( slope)  I will generate unique landslide potential value.
something like you see, landslide is
     a slope movement so I have to say, this slope is unstable but
adjacent slope is stable)
    Unfortunately, while r.terraflow generates very good and realistic
watershed basin map, it does not generate
    half basin map. ( as far as I see r.watershed's basin is not as good
as r.terraflow's basin)
>> Firstly, I used PostGis's extent function and got width and length of
>> polygons (say watershed or  landslide as polygon). But this
>> polygon's longest dimension doesn't fit dimension in downslope
>> direction, which is the slope length I am looking for. So, if I found
>> max and min values of elevation of the polygons, I could calculate
>> slopes' length.
> This does not sound like a realistic solution, as the extent() function will
> return a minimum bonding box -- which provides the maximum 'length'
> and 'width' of some polygon, but not much useful information.
>> /*v.rast.stats */gives max and min values of elevation of the polygons(
>> /*v.rast.stats*/ has  still been running for most 20 hours).
>> maybe from these values I generate vector points containing min & max
>> values .
> Do you have a number of polygons, and the specifications for your DEM: cell
> size, region size? You may have hit some upper boundary for v.rast.stats.
> Starpan seems to scale very well, so you may not run into this problem.
>> I will appreciate if you supply your ideas and recommendations
>> regards
> Sure. With a clearer statement of the problem, and some information on your
> source data it may be possible to come up with a workable solution.
> Cheers,
Ahmet Temiz
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
