[GRASS-user] Problems with r.le.setup
andrew.haywood at poyry.com
Thu Feb 8 00:39:24 EST 2007
Dear All,
just compiled grass63 on a suse10.2 and am now having problems running
r.le.setup.
I would like to do the analysis centered on site but when I get to the
last stage of selecting the sites vector the following error occurs.
WARNING: Adapted sites library used for vector points (module should be
updated to GRASS 6 vector library).
ERROR: G_get_site() not yet updated.
I have created the sites using v.in.ascii command and it contains
x,y,z,cat,
Any suggestions on how I can calculate texture attributes for the site
locations would be appreciated.
cheers
Andy
This email and any files transmitted with it are confidential, may be legally privileged and are intended solely for the use of the individual or entity to whom they are addressed. If you are not the intended recipient, you are hereby notified that any use, distribution, or reproduction of the contents of this email is strictly prohibited and may be unlawful. If you are not the intended recipient, please notify the sender by return email and destroy all copies of the original message including any attachments thereto.
Thank you.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070208/4bbbac0f/attachment.html
