[GRASS-user] Problems with r.le.setup
Paolo Cavallini cavallini at faunalia.it
Thu Feb 8 02:15:46 EST 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I would suggest you to give r.li a try: it is much faster, presumably
more stable, and easier to customize.
pc
andrew.haywood at poyry.com ha scritto:
> Dear All,
> just compiled grass63 on a suse10.2 and am now having problems running
> r.le.setup.
> I would like to do the analysis centered on site but when I get to the
> last stage of selecting the sites vector the following error occurs.
> WARNING: Adapted sites library used for vector points (module should be
>          updated to GRASS 6 vector library).
> ERROR: G_get_site() not yet updated.
> I have created the sites using v.in.ascii command and it contains x,y,z,cat,
> Any suggestions on how I can calculate texture attributes for the site
> locations would be appreciated.
> cheers
> Andy
> This email and any files transmitted with it are confidential, may be
> legally privileged and are intended solely for the use of the individual
> or entity to whom they are addressed. If you are not the intended
> recipient, you are hereby notified that any use, distribution, or
> reproduction of the contents of this email is strictly prohibited and
> may be unlawful. If you are not the intended recipient, please notify
> the sender by return email and destroy all copies of the original
> message including any attachments thereto.
> Thank you.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Paolo Cavallini
email+jabber: cavallini at faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFFys4h/NedwLUzIr4RArfRAJ9s2phwTnkRsRaGAWJvvlqEKXohSQCglU3M
VxorOaX1kAmkeB3xO8IgQtw=
=nGMC
-----END PGP SIGNATURE-----
