[GRASS-user] r.fillnulls in the latest cvs version doesn't work appropriately
Martin Landa landa.martin at gmail.com
Fri Feb 9 13:04:41 EST 2007
this bug should be fixed in CVS now.
Martin
2007/2/9, Hamish <hamish_nospam at yahoo.com>:
> Maciej Tomaszczyk wrote:
> > r.fillnulls in the latest cvs version doesn't work appropriately.
> > GRASS 6.3.cvs (polska_srtm):~/grass > r.fillnulls input=N49E018
> > output=N49E018_fill tension=40. smooth=0.1 Locating and isolating NULL
> > areas...
> >  100%
> > WARNING: Use the -m flag in combination with other print flags.
> That is due to a bug in g.region.
> LatLon:> g.region -gm
> (and no result)
> -g implies that you want output. You shouldn't have to add -p as well.
> I still don't fully understand the logic of why it was changed.
> Hamish
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
