[GRASS-user] r.fillnulls in the latest cvs version doesn't
	work appropriately
    Michael Barton
    michael.barton at asu.edu
    Tue Feb 13 09:19:44 EST 2007
Thanks Martin. As long as the flags don't change and the format of their
output doesn't change, there will be no problem with the GUI.
Michael
On 2/13/07 1:04 AM, "Martin Landa" <landa.martin at gmail.com> wrote:
> Hi Michael,
> 2007/2/12, Michael Barton <michael.barton at asu.edu>:
>> Please let me know when the dust settles on how g.region is going to work
>> now in GRASS 6.3.
>> It is critical to the functionality of the GUI. A month or so back, I had to
>> switch all the calls from g.region -g to g.region -gp. While I'd prefer not
>> to have to switch them back, it is not a big effort to do so. I just need to
>> know which syntax is going to be used.
> I understand, sorry for these complications, g.region -pg still
> working as g.region -g. I hope there is no problem with print flags in
> g.region. This behaviour should be stabilized.
>> If there is going to be a change in g.region that could potentially break
>> the GUI, it would be best if we could coordinate the changes to avoid this.
> OK, the flags behaviour should be frozen. I would like to implement
> print option.
> Martin
>> Michael
>> On 2/12/07 5:36 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
>>> Martin Landa wrote:
>>>> I am trying to revert the changes. I think it is better to implement
>>>> print option from the scratch then trying to change the existing flags
>>>> behaviour. I agree that all scripts written for GRASS 6.x should work
>>>> without any modification. These changes should come with new version
>>>> of GRASS (GRASS 7.x). The question is when it will be. Maybe we should
>>>> collect more detailed ideas for GRASS7.
>>> There's no reason why you can't add the print= option in 6.x. Adding
>>> entirely new functionality is safe, so long as it doesn't affect
>>> anything which doesn't explicitly use it.
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics and Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
Center for Social Dynamics & Complexity
phone: 480-965-6213
fax: 480-965-7671
