[GRASS-user] r.fillnulls in the latest cvs version doesn't work
appropriately
Martin Landa
landa.martin at gmail.com
Tue Feb 13 03:04:29 EST 2007
Hi Michael,
2007/2/12, Michael Barton <michael.barton at asu.edu>:
> Please let me know when the dust settles on how g.region is going to work
> now in GRASS 6.3.
> It is critical to the functionality of the GUI. A month or so back, I had to
> switch all the calls from g.region -g to g.region -gp. While I'd prefer not
> to have to switch them back, it is not a big effort to do so. I just need to
> know which syntax is going to be used.
I understand, sorry for these complications, g.region -pg still
working as g.region -g. I hope there is no problem with print flags in
g.region. This behaviour should be stabilized.
> If there is going to be a change in g.region that could potentially break
> the GUI, it would be best if we could coordinate the changes to avoid this.
OK, the flags behaviour should be frozen. I would like to implement
print option.
Martin
> Michael
> On 2/12/07 5:36 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> > Martin Landa wrote:
> >> I am trying to revert the changes. I think it is better to implement
> >> print option from the scratch then trying to change the existing flags
> >> behaviour. I agree that all scripts written for GRASS 6.x should work
> >> without any modification. These changes should come with new version
> >> of GRASS (GRASS 7.x). The question is when it will be. Maybe we should
> >> collect more detailed ideas for GRASS7.
> > There's no reason why you can't add the print= option in 6.x. Adding
> > entirely new functionality is safe, so long as it doesn't affect
> > anything which doesn't explicitly use it.
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
