[GRASS-user] r.fillnulls in the latest cvs version doesn't work appropriately
Sat Feb 10 13:04:43 EST 2007
Martin Landa wrote:
> 2007/2/10, Michael Barton <michael.barton at asu.edu>:
> > Beyond the larger issue of how the complex command g.region should be
> > controlled (which has already had considerable discussion), won't replacing
> the last Glynn's notes about print parameters make sense to me.
> > g.region -gm with g.region -gpm fix the immediate problem with the r.nulls
> > shell script?
> I hope I fixed this problem or I missed something? Now:
> g.region -m == g.region -gm (== g.region -pgm)
Actually, I don't consider -gm => -gpm to be "correct"; what do you
use if you *only* want the resolution in metres, and not the region?
Explicitly adding -p in r.nulls is preferable, IMHO.
