[GRASS-user] r.fillnulls in the latest cvs version doesn't
	work appropriately
    Michael Barton
    michael.barton at asu.edu
    Sat Feb 10 14:04:12 EST 2007
I agree that the larger issues for g.region need to be sorted out. But can
the script be made functional in this way until they are?
Michael
On 2/10/07 11:04 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Martin Landa wrote:
>> 2007/2/10, Michael Barton <michael.barton at asu.edu>:
>>> Beyond the larger issue of how the complex command g.region should be
>>> controlled (which has already had considerable discussion), won't replacing
>> the last Glynn's notes about print parameters make sense to me.
>>> g.region -gm with g.region -gpm fix the immediate problem with the r.nulls
>>> shell script?
>> I hope I fixed this problem or I missed something? Now:
>> g.region -m == g.region -gm (== g.region -pgm)
> Actually, I don't consider -gm => -gpm to be "correct"; what do you
> use if you *only* want the resolution in metres, and not the region?
> Explicitly adding -p in r.nulls is preferable, IMHO.
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
